20 Most Recent
Fendi /eta Watch Movement Eta 980.105 7 Jewel Quartz Runs Swiss V8 389 Questions & Answers
I have a dz09 smartwatch and when I go to connectivity it says empty. What am I suppose to do?
NIGHT FALL
Choosing the right watch depends on your lifestyle, budget, and decide the purpose-daily wear, formal occasions, sports, or smart features. Choose a comfortable size, a reliable movement (quartz for accuracy, automatic for tradition, smartwatch for tech), and durable materials like stainless steel with good water resistance. A good watch should match your routine, feel comfortable on your wrist, and suit your overall look .High end watch shop.
For more details explore our website:
https://dev-night-fall.pantheonsite.io/
4/28/2026 11:01:58 AM •
Watches
Answered
on Apr 28, 2026
I want to renew my
Renew by Mail if All of the Following are True:
Your Most Recent U.S. Passport:
Is undamaged and can be submitted with your application
- Was issued when you were age 16 or older
- Was issued within the last 15 years
- Was issued in your current name or you can legally document your name change
If any of the above statements do not apply to you, you must Apply in Person
A Note on the U.S. Passport Card:
If you are a previous passport book holder and you are eligible to use Form DS-82, you may apply for a passport card as a
renewal by mail - even if it is your first passport card!
How to Renew Your U.S. Passport by Mail:
From Inside the United States:
To renew your U.S. Passport by mail, you must submit Form DS-82, Application for a U.S. Passport by Mail. Locate Form DS-82 and step-by-step instructions at Form DS-82: Application for a U.S. Passport by Mail.
From Outside the United States:
U.S. citizens residing abroad (except those living in Canada) should renew their passports at the nearest U.S. Embassy or U.S. Consulate.
Need a U.S. Passport Immediately?You should make an appointment to be seen at a Regional Passport Agency only if:
- The U.S. passport is needed in less than 2 weeks for international travel
- The U.S. passport is needed within 4 weeks to obtain a foreign visa
Contact the National Passport Information Center to make an appointment or locate a Passport Agency.
Read more here: http://travel.state.gov/passport/renew/renew_833.html I’m happy to help further over the phone at
https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
3/25/2026 12:20:03 PM •
Watches
Answered
on Mar 25, 2026
KADIO KD-3806 Model watch.
ALL PARAMETERS CAN BE ADJUSTED BY USING KEYS
GIVEN BACKSIDE...KEYS ARE
MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS;
UP/DOWN TO CHANGE THE PARAMETERS; \
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING;
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything .....
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time
1/21/2026 7:42:26 PM •
Watches
Answered
on Jan 21, 2026
Need directions for a Armitron 20-3454 7
You can get instructions from the Amitron web site.
Copy "www.armitron.com/watch_instructions.asp" into your search engine
and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file.
10/21/2025 8:14:28 AM •
Watches
Answered
on Oct 21, 2025
How to set Harve Benard watch 20-093
General Steps for Analog Watches
- Pull the crown (the knob on the side) out gently to the first or second "click" position.
- First click: often to set date/day (if your watch has that).
- Second click: sets the time.
- Turn the crown to set the hour and minute hands to the correct time.
- Push the crown back in fully to restart the movement.
- If your watch has a date/day complication, after you push the crown in half-way (first click) you may turn to adjust the date/day, but avoid doing this around midnight (say between 9pm and 3am) since it may damage the mechanism.
According to generic quartz watch instructions:
"To set your watch's time... pull the crown fully out... gently turn the crown..." Manuals+
- If your watch is water-resistant with a screw-down crown, you may have to unscrew the crown first (turn counter-clockwise) before pulling it out. Then screw back in after setting.
?? Specific Tip from a User Guide for Your Model
I found a user question on FixYa for "How to set Harve Benard Watch 20-093". The advice given:
"Press and hold the button on the top right side of the watch: Press and hold the button until the time display appears. Set the time: Use the ..." Fixya
This suggests your model might have digital/chronograph features (i.e., a "button on the top right" rather than only a crown). If so:
- Press and hold the top-right button until the display starts flashing (time-set mode).
- Then use other buttons (often the side bottom or top left) to cycle hours/minutes.
- Press again to confirm and exit.
? What to Check & Do
- Verify whether your watch has only a standard crown, or also buttons (top right / side) - this determines analog vs digital mode.
- If it's a digital display or hybrid (hands + digital), look for a mode button or "Set"-function via one of the buttons.
- Ensure the battery is fresh so the watch responds correctly when you try to set it.
- After setting the time, check for accuracy by matching it to a reliable clock
10/19/2025 6:39:45 PM •
Watches
Answered
on Oct 19, 2025
How to set time on accurist 774
Use the following process to set the hands to required time.
Fist follow the following steps to set the analogue hands to the 1200 position (straight up)
1. Press the lower right button until the mode indicator hand
points to TME.
2. Pull the lower right button out one click. Press the other
three buttons down simultaneously for three seconds and
release. You will see 8's on the digital display.
3. Press the upper left button. You will see UTC on the top half
of the digital display. Press the upper right button to advance
the hands of the top dial to the straight up 24-hour position.
Use the lower left button to go in reverse.
4. Press the upper left button. You will see HR on the top half
the hour and 24-hour hand clockwise until they both point
straight up at the 24-hour position. Use the lower left button to
move the hand anti-clockwise.
5. Press the upper left button. You will see MIN on the top half
the minute hand clockwise or the lower left button to move
anti-clockwise until it is pointing straight up at the 12 O'clock
position.
6. Push the lower right button back in one click
Then, pull out lower right button and set digital clock to correct time and date.
When digital time setting complete, push the lower right button in one click.
The analogue watch hands should now align to the digital clock settings.
Happy Days.
10/7/2025 8:08:19 AM •
Watches
Answered
on Oct 07, 2025
Hi I'm Judy. I am 72 years old and not "hi tech" . My watch shows correct Date but not the correct time. How can I set the correct time on the watch? Simple directions would be much appreciated.
Hi Judy! I'd be happy to help you set the time on your watch. Since you didn't mention the brand or type (like digital with buttons, analog with a crown knob, or a smartwatch), I'll give simple steps for the most common kinds. If these don't match your watch, can you tell me a bit more about it (e.g., does it have buttons on the side, or a twisty knob)? That way, I can give exact instructions.
If it's a digital watch (with a screen showing numbers and buttons on the side):
- Look for buttons on the right side of the watch (usually 2 or 3 small ones). Press and hold the top button (often labeled "Mode" or with a clock icon) for 3-5 seconds until the display starts flashing (this enters "set time" mode).
- Use the bottom button to scroll through the hours until you reach the correct hour. Press the top button to move to minutes.
- Use the bottom button again to set the correct minutes.
- Press and hold the top button (or a side button) to save and exit. The display should stop flashing.
- If there's a light button, press it if needed to see better.
If it's an analog watch (with hands for hours/minutes and a small date window, set with a crown knob on the right side):
- Pull the crown (the twisty knob on the side) out gently to the first position (it might click). This usually sets the date- but since your date is already correct, skip adjusting it.
- Pull the crown out a bit further to the second position (full out). The hands should now move freely.
- Turn the crown clockwise (or counterclockwise, depending on the watch) to set the hour and minute hands to the correct time. Go forward past 12 if needed to avoid messing up the date.
- Push the crown back in firmly to the normal position to lock it.
- Wait until the next minute starts before setting exactly, so it keeps good time.
Test it by wearing it for a few minutes to see if it ticks correctly. If it's a battery-powered watch and still wrong after this, the battery might be low-consider taking it to a jeweler for a quick check (it's often free).
9/23/2025 8:24:25 AM •
Watches
Answered
on Sep 23, 2025
