20 Most Recent LG 42LC2D 42 in. LCD HDTV Questions & Answers
6answers
LG TV keeps flashing This function is not available now.
unplug the TV. hold down the power button for 30 seconds. plug the TV in.
this worked for me :)
12/11/2025 11:07:03 AM • LG 42LC2D 42 in.... • Answered on Dec 11, 2025
Lg tv model no 21sa1rg4tp/2010
Can u told me which brands speaker inside thi model
10/26/2023 4:13:50 PM • LG 42LC2D 42 in.... • Answered on Oct 26, 2023
What "hd service" message means?
High Defination tv mean the picture rate in 1080p.The picture very clear and close to real as mush as possible.
10/14/2023 3:35:23 PM • LG 42LC2D 42 in.... • Answered on Oct 14, 2023
Lookig for Manual for 42in plasma HD TV. Model #
for your manual just click at google .com and then manuals. for your remote you can buy the universal on best buy walmart or frys
12/25/2022 6:02:03 AM • LG 42LC2D 42 in.... • Answered on Dec 25, 2022
5answers
LG DVD Remote to control TV
The procedure is simple. Hold down the TV POWER button and press a number botton. Release the TV POWER button. The manuel gives the following list of codes: LG/GoldStar....1 (predetermined), 2 Zenith...1, 3, 4 Samsung... 6, 7 Siny... 8, 9 Hitachi... 4
I have an RCA and 6 worked for me.
-olivares1900
5/25/2022 9:17:17 PM • LG 42LC2D 42 in.... • Answered on May 25, 2022
4answers
My lg xcanvas 42 plasma
Hi.
You need to reach the Option menu, and to set the language. You will have to do this working on the Korean menu. I hope that the pictures below may help:
Press MENU button on remote, and go to OPTION menu, which is the one with a tag picture, right on top of the padlock pic.
Use the arrow buttons to select language. use arrow right to confirm and up and down to select.
Below a manual for this model:
LG 42LC2D
Regards.
Ginko.
4/5/2022 12:26:19 AM • LG 42LC2D 42 in.... • Answered on Apr 05, 2022
2answers
How to fix a crack inside a LG LCD TV
The short answer is a cracked LCD is not worth repairing.Here is a link to some more info, cover cost and whats involved.Broken Screen's Repair and Info Cracked, Broken, Smashed Bad LCD, Plasma and LED Panels
12/2/2021 7:19:11 PM • LG 42LC2D 42 in.... • Answered on Dec 02, 2021
I have a 42 inch lg plasma,and everytime i hook up
ok, have you tried hooking up your PS3 to a different tv and it work? if so, you may have to change the settings in the PS3 to fit the LG tv. or, it may be in the menu options of the tv for a specific channel or setting. reading directions for hookup is a big help too:P
9/28/2021 6:19:03 AM • LG 42LC2D 42 in.... • Answered on Sep 28, 2021
3answers
LG 42LG5 TURN ON TV PICTURE GOES BLACK
This could be 1 of a few things here. Without opening up your set and trying to look at voltages or indiciator lights I couldn't tell you exactly without some more info.
Without looking at it myself here are my thoughts and where I would first look at.
It may be a main board because:
1) Main board processes all your audio/video signals. Bad main board means bad video processing. Could do that. Especially if the main board is not sending the right signal or a bad signal to the rest of the boards so they don't do their jobs.
It may be a power supply because:
1) Power supply is well, the power supply. If it's sending inadaquete voltage to the main board you may not be recieving enough juice to keep that main board doing your video processing or further up the line keeping enough juice flowing to your TCon board to keep it telling things where to go and what to do. The power supply sends voltages to your Ballast board(controls your lights) and to your main board through which power is supplied to your TCon board via a LVDS line and a +12/+16V signals. If the power supply isn't pumping out enough juice to keep the TCon or Main Board running, it could be a problem. By the same token it could be that your P/S isn't sending power out to your ballast board.
It could be a TCon because:
1) If the TCon is bad, you won't get your pictures. This could be the TCon board itself or the LVDS cable from your TCon to your Main. However, with few exceptions, if it's a bad TCon you're looking at a total panel replacement.
It could be a ballast board because:
1) The Ballast Board controls the lighting behind the LCD screen. If this isn't working right you won't be seeing much of anything without that back lighting. If this is bad, it's a panel replacement. These are not field replaceable items by LG.
Based on the symptoms, without more data or a eyes-on view of it, I would say you're most likely looking at a Main Brd or PSU problem.
2/12/2021 11:13:16 PM • LG 42LC2D 42 in.... • Answered on Feb 12, 2021
7answers
LG LCD HDTV 'NO SIGNAL'
To fix the problem, try turning off the TV and unplugging it from the outlet. Once unplugged, push the power button and hold it down for 1 minute. Then turn the TV back on and rescan for channels.
If the problem persists, contact LG customer service immediately as there is a problem with the memory card. The device is unable to retain scanned channels for immediate feedback.
All LG LCD automatically comes with a 1 year manufacturing warranty. You would have to provide proof of purchase to show when it was purchased. Hope this helps. The Guru
LG customer service: http://www.lg.com/us/support/index.jsp
5/4/2020 12:07:54 PM • LG 42LC2D 42 in.... • Answered on May 04, 2020
Tv turns on green light blinks three times then TV turns off
Ur power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
5/4/2020 6:05:46 AM • LG 42LC2D 42 in.... • Answered on May 04, 2020
2answers
Samsung lcd 32 inch tv has vertical lines in color about 4 inches wide all over the screen and it has no picture but it has audio
Only boards are sold and no parts- a 32 inch may not have even the boards or be cost effective to repair----suspect main board here.
10/28/2019 5:07:31 PM • LG 42LC2D 42 in.... • Answered on Oct 28, 2019
9answers
The tv sensor is not working on my 42" lg lcd hdtv
Believe it or not...THIS WORKS!!!!
 Look on the back of your set for an external remote jack. It should be the same size as a small headphone jack. If it has one, use a spare headphone plug or your headphones, and plug them in and out about 50 times. This will clean the tarnished contacts and make your remote sensor start working. Your remote sensor goes through a switch on this jack.
5/25/2019 12:22:04 AM • LG 42LC2D 42 in.... • Answered on May 25, 2019
15answers
42 in LG LCD TV turns off by itself
Found that TV started switching off by itself. Would try to come on..green light blinked for 2-3 seconds, tv came on (with picture and sound) for 1 or 2 seconds and then it would turn itself off. Found that the issue is with one channel only. If you are facing this issue....try quickly changing the channel the moment it comes on. You can do it either with remote or with the TV buttons directly. also in the same logic, if this is still happening, try changing the source to another (rgb-pc, av1, av2 etc). Basically change it from whatever input it is on currently, if changing the channels does not work. My symptom was that the tv made a loud 'TIK' 'TAK' sound which is louder than normal.
11/15/2018 5:43:21 AM • LG 42LC2D 42 in.... • Answered on Nov 15, 2018
3answers
KEEPS SAYNG NOT PROGRAMMED TO WATCH NORMAL CHANNELS
Do a first time installation, move the TV or bite the bullet and either buy an external aerial or extend the main house aerial cable to reach the TV. assuming your TV has no signal where it is now
11/1/2018 11:54:59 PM • LG 42LC2D 42 in.... • Answered on Nov 01, 2018
2answers
42" Lcd problem
I belive the repair shop might be try to get more money from you
if you enscrew the back of the tv ( with the tv unplugged ) look for a flat wirestrip thats not connected
I think they either forgot to plug in that video wire or they did it to make money from you
did it work fine before the dim screen or did it come back to you like that?
10/29/2018 6:35:09 AM • LG 42LC2D 42 in.... • Answered on Oct 29, 2018
0answers
Screen shadow crease
do you have speaker on each side if so move a way from TV
2/13/2018 1:15:27 AM • LG 42LC2D 42 in.... • Answered on Feb 13, 2018
TV is slow to turn on
It looks like an electrolytic cap. on the power supply. you may find that the guilty one is bulging on the top.
1/24/2018 10:35:14 AM • LG 42LC2D 42 in.... • Answered on Jan 24, 2018
How do i hookup a dvd player and a wii at the same
You can use an HDMI converter for your wii
1/17/2018 1:35:47 PM • LG 42LC2D 42 in.... • Answered on Jan 17, 2018
LG 42LC2D 42 in. LCD HDTV Logo
3,065 questions posted
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
View Most Popular
  • LG Televison & Video
Most Popular Question
lg tv keeps flashing function not
  • Televison & Video
