20 Most Recent Milwaukee tools Milwaukee 0719-22 M28 Lithium-Ion Cordless Sawzall 1 Bat Questions & Answers
3answers
How to install a fence?
Waht fence do you want to install. Is it a boundary fence? I ask because a radial arm saw also comes with a fence. It is always better to give too much info than too little.
2/4/2026 6:07:52 AM • Saws • Answered on Feb 04, 2026
How do you attach a stacked dado set to the Chicago Electric table saw? I could not find useful instructions in the manual or online. The arbor does not seem long enough
Your saw will accept stacked dado if arbor is short, do not attempt to place or run dado stack, serious injury may occur.You may be able top find a "wobble dado blade".
10/9/2025 4:24:42 PM • Saws • Answered on Oct 09, 2025
Element HDTY 32 powers blue; but no picture or sound
  • Input/Source Mismatch: TV is on the wrong HDMI, antenna, or app source.
  • Cable/Connection Issues: Loose or faulty HDMI/AV cables, or port damage.
  • Backlight or Display Failure: Power light works, but LED backlight is out (TV is "on" but screen appears black).
  • Audio/Software Glitch: Firmware bug, muted sound, or speaker failure.
  • Power Supply Problems: Partial failure in the internal board, causing AV dropout without full shutdown.
  • Overheating or Age: Dust buildup or component wear in older units.
Step-by-Step Troubleshooting
  1. Verify Basic Power and Connections:
    • Ensure the TV is plugged into a working outlet (test with another device). The blue light confirms power, but try a different cord if available.
    • Check all cables: Unplug/replug HDMI (from cable box, streaming device), antenna, or optical audio. Switch to a different HDMI port (most models have 2-3).
    • Press the power button on the remote or TV (hold for 5 seconds) to cycle off/on-wait 30 seconds between.
  2. Adjust Input Source and Settings:
    • Use the remote's "Input" or "Source" button to cycle through options (e.g., HDMI1, TV, USB). If stuck, enter menu (Settings > Input) and select the correct one.
    • Check volume: Ensure it's not muted (press Vol+ or check remote batteries). Go to Settings > Audio > Speakers On.
    • Shine a flashlight on the screen in a dark room-if you see a faint image, it's a backlight issue (common in Element LEDs; screen works but lights are dead).
  3. Perform a Soft Reset:
    • Unplug the TV from the wall for 5-10 minutes (this discharges capacitors and resets firmware).
    • While unplugged, press and hold the power button on the TV for 30 seconds to drain residual power.
    • Plug back in and turn on. If it has a factory reset option: Settings > System > Reset (this erases apps/settings-back up if possible).
  4. Test Hardware and Audio:
    • Connect a different device (e.g., DVD player or phone via HDMI) to rule out source problems. If no picture/sound persists, it's the TV.
    • For sound: Try external speakers/headphones via headphone jack or Bluetooth (Settings > Audio > Output). If external works, internal speakers may be faulty.
    • Inspect vents: Clean dust from back/sides with compressed air (TV off/unplugged) to prevent overheating shutdowns
10/7/2025 10:43:33 AM • Saws • Answered on Oct 07, 2025
My Rigid wet saw (r4040) wont run. It sparked and tripped the breaker now it won't run. Is there a reset button or something I need to do on it?
  • Find the motor housing: On some models, the overload reset button is a red button located on the motor housing, often near the power cord entry.
10/5/2025 6:10:15 PM • Saws • Answered on Oct 05, 2025
2answers
How do adjustable height tables work?
Adjustable height tables, like those offered by RDM Industrial Products, operate using mechanisms that allow users to change the table's height according to their needs. These tables typically feature electric or manual adjustments that enable easy raising or lowering of the tabletop. RDM Industrial Products offers a range of adjustable height tables designed for ergonomic comfort and versatility. For more details, you can explore their offerings at https://www.rdm-ind.com/
9/23/2025 10:48:12 AM • Saws • Answered on Sep 23, 2025
Sony Play Station PS4. I have 141 GB space left and saw Elder Scrolls online in the PS4 network, but when I bought it, it said not enough space on hardware. Why do I need more space?
Old question!Question edited for clarity, add full make model, add CAPS, fix typos.Question moved from Scroll Saws category.https://www.google.com/search?q=elder+scrolls+memory+requirements..
9/11/2025 12:41:19 PM • Saws • Answered on Sep 11, 2025
Do I need a building permit to install a fence
Yes, you may need a permit if your fence is tall, in the front yard, or made of certain materials. For a simple backyard fence under 6 ft, most places do not require one - but always confirm with your local office.
9/11/2025 12:24:05 PM • Saws • Answered on Sep 11, 2025
How can i set saw to cut dados and is there a video?
A sliding miter/chop saw like your Chicago Electric can cut dados, but only by making repeated shallow passes - you cannot install a dado blade stack (that's for a table saw). How to Set It Up 1. Mark the dado on your board (width and depth). 2. Adjust depth stop on your saw so the blade only cuts down to the depth you need (not all the way through). 3. Make the first cut along one edge of the dado. 4. Slide the board slightly and keep making passes until the whole groove is cleared. 5. Clean up the bottom with a chisel if needed. Clamp your work securely - you'll be making several cuts side by side. Never try to mount a dado blade set on a miter saw; it's unsafe. Answer: You set your saw by using the depth stop to control cut depth and then make multiple overlapping cuts across your dado area. It works fine for occasional grooves, though a table saw or router is faster. Would you like me to draw a simple diagram showing how to position the work and blade for the dado passes?
9/11/2025 12:21:52 PM • Saws • Answered on Sep 11, 2025
Can I buy athe machined aluminum fence for my Chicago Electric 61790 mitre saw
Yes, you can buy a machined aluminum fence / upgrade for a Chicago Electric miter saw - but probably not off the shelf for the 61790 model exactly. You'll likely have to: 1. Adapt a universal/extruded aluminum fence. 2. Possibly get one custom-made locally to fit precisely. 3. Modify mounting holes or brackets to match your saw.
9/11/2025 8:58:39 AM • Saws • Answered on Sep 11, 2025
Saw keeps cutting out when cutting
Common Causes & Fixes 1. Worn Carbon Brushes * The most common cause. When brushes wear down, the motor loses contact and cuts out. * Fix: Inspect and replace the carbon brushes (cheap and fairly easy). 2. Overheating / Thermal Cut-Out * Many saws have a thermal protector. If you push too hard or cut continuously, it overheats and shuts off. * Fix: Let the saw cool down, clean vents, and avoid forcing the cut. 3. Loose Power Connection * A loose power cord, plug, or internal wiring can interrupt power. * Fix: Check the cord for breaks or kinks, and ensure it's firmly seated. 4. Faulty Trigger Switch * Worn or dirty contacts in the on/off switch can cause intermittent cutting out. * Fix: Switch may need cleaning or replacing. 5. Dust Build-Up Inside Motor * Sawdust can clog vents and interfere with motor brushes or cooling. * ? Fix: Blow out the motor housing with compressed air. 6. Overloaded Circuit * If your saw is on a long extension cord or weak breaker, it may trip under load. * Fix: Plug directly into a good outlet (no thin extension cords). Quick Checklist * Unplug saw ? check brushes. * Clean out dust and check vents. * Inspect power cord & plug. * Test on a different outlet. * If still cutting out ? suspect switch or motor winding issue (may need professional repair).
9/11/2025 8:56:02 AM • Saws • Answered on Sep 11, 2025
Are bushes easy to on a macallister sliding chop saw
What you can do 1. Contact parts suppliers or metal fabricators locally: Ask if they can make you a machined aluminum fence to your saw's specs (height, thickness, mounting hole pattern). 2. Search after-market or universal fences that can be adapted. Sometimes a universal aluminum miter saw fence (or aluminum angle bar + T-track etc.) can be fitted with minor mods. 3. Check with Harbor Freight / Chicago Electric support: maybe they have a heavy-duty or premium upgrade fence.
9/11/2025 8:51:15 AM • Saws • Answered on Sep 11, 2025
How to tighten a blade with no blade lock? Even when I stop the blade it will not tighten.
Question Moved from Misc to Circular Saws.Duplicate Question deleted, just Refresh the page to see.Help and videos. Make sure the bolt is not a left hand thread.https://www.google.com/search?q=How+to+tighten+a+circular+saw+blade+with+no+bladelock..
8/7/2025 7:25:35 PM • Saws • Answered on Aug 07, 2025
Ihave a doall saw model c430a the head will just drop into the piece with no reason
, it's likely a hydraulic issue-specifically with the feed rate control valve or counterbalance system. - Hydraulic Feed Control Valve Malfunction - The valve regulates how fast the head descends. - If it's stuck open or bypassing internally, the head will drop too fast.. Fix: Inspect and clean the valve. Replace if worn or leaking. - Counterbalance Cylinder or Bleed Valve Issue - Some models use a hydraulic cylinder with a bleed valve to control descent. - If fluid leaks past the valve, the head may fall uncontrolled. Fix: Adjust the bleed valve or rebuild the cylinder if seals are worn. - Low Hydraulic Fluid or Air in System - Air bubbles or low fluid can cause erratic movement. - Fix: Check fluid level and bleed the system. - Broken or Disconnected Feed Rate Linkage - Mechanical linkages between the control knob and valve may be loose or broken. - Fix: Inspect for broken pins, loose set screws, or disconnected rods. Reference & Parts You can find exploded views and manuals for your C430A model on DoALL's official parts manual page. If you need schematics or want to order replacement components, that's the best starting point. /
7/28/2025 4:03:58 AM • Saws • Answered on Jul 28, 2025
Duracraft Bandsaw VS-312 need the manual please. Can anyone help or point me in the right direction? Or do you know if this exact bandsaw was sold by another brand name?
Old question resurrected by spam now removed.There are manuals here that may be close enough. They all work to the same theme. It appears it in not known under another maker name.https://www.google.com/search?q=Bandsaw+VS-312+manualMore on it here.https://www.google.com/search?q=Duracraft+Bandsaw+VS-312..
7/21/2025 5:47:17 PM • Saws • Answered on Jul 21, 2025
DeWalt DW100, 1510mm (59½”) Wood Cutting Bandsaw. It cuts at a weird angle, tried adjusting everything I can, but can't straighten it. Any ideas please?
Old question resurrected by spam, now removed.Replace the saw band with a new one. Make sure the tension is correct. It may also be wear on the drive tyre.https://www.google.com/search?q=DeWalt+DW100+cuts+off+angle..
7/21/2025 5:32:09 PM • Saws • Answered on Jul 21, 2025
I have a 20 year old Calligaris glass top table that has roll top extensions. I moved & the mover took it apart! Now the roll top part does not stay in the track anymore.
That sounds like a frustrating situation, especially with a piece you love. Calligaris tables-especially older models with roll-top extensions-can be tricky to reassemble without the original guides or hardware. But there's hope! What You Can Do Contact Authorized Calligaris Dealers Nearby You've got a few solid options within reach of Central New Jersey:
7/20/2025 5:16:17 PM • Saws • Answered on Jul 20, 2025
Saw cuts out when cutting
Old Question!! All question need full 'make model (what it is)', or we have to guess! If it electric, replace the carbon brushes in the motor.
Saw stops cutting midway through large trees : r/Chainsaw
Reddit · r/Chainsaw 10+ comments · 3 years ago It's a chain issue. Typically your rakers (fine, fine, depth gauges) are too high. Especially after your chain has been sharpened a few times ... Saw "stops" cutting after a few inches : r/Chainsaw - Reddit 17 posts Jul 18, 2020 Stalls out when cutting bigger pieces. : r/Chainsaw - Reddit 35 posts Dec 6, 2018 More results from www.reddit.com
Chainsaw runs fine but stalls in cut after a few seconds
The Forestry Forum https://forestryforum.com > board Mar 19, 2024 - In my experience, if a saw will idle fine and start to cut but then dies after a few seconds in the cut, you have a serious restriction in the ...
Why does your chainsaw cut out randomly when ...
Quora 1 answer · 2 years ago The most common reason is that the wood moves in such a way as to increase the friction on the chain. If there friction exceeds the power of the ...
6/13/2025 5:04:44 AM • Saws • Answered on Jun 13, 2025
Craftsman 113.298721 Table Saw. Is there a manual please?
Old question!!
Question edited for clarity and spelling of maker 'Craftsman' with 's'.
Sears 113.298721, 113.298761 Owner's Manual
ManualsLib https://www.manualslib.com > manual > Sears-113-298... View and Download Sears 113.298721, 113.298761 owner's manual online. 10-INCH TABLE SAW. 113.298721, 113.298761 saw pdf manual download. Also for: 298721.
owners manual
Sears PartsDirect https://c.searspartsdirect.com > lis_pdf > OWNM PDF FULL ONE YEAR WARRANTY ON CRAFTSMAN. TAB LE SAW. If within one year from the date of purchase, this Craftsman Table Saw fails due to a defect in material or ... 52 pages Missing: 113.298721 ‎' Show results with: 113.298721
Model # 113298721 Official Craftsman table saw
Sears PartsDirect https://www.searspartsdirect.com > model > craftsman-1... Here are the diagrams and repair parts for Official Craftsman 113298721 table saw, as well as links to manuals and error code tables, if available. Profile Icon ...
Craftsman 113.298761 Specifications : Free Download, ...
Internet Archive https://archive.org > details > manualzilla-id-7445003 Jul 28, 2021 - Safety is a combination of common sense, staying alert ; and knowing how your table saw works. Read this ; manual to understand this saw.
Instruction Manual Fits Craftsman 10" Table Saw ...
eBay https://www.ebay.com > ... > Power Saws > Table Saws Instruction Manual Fits Craftsman 10" Table Saw 113.298721 113.298761 ; Item number. 175387781334 ; Brand. Unbranded ; Blade Diameter. 10 in ; Accurate description. US$16.99
Sears Craftsman 113.298721 Manuals
ManualsLib https://www.manualslib.com > ... > Sears Manuals > Saw Sears Craftsman 113.298721 Owner's Manual (56 pages). 10-INCH TABLE SAW. Brand: Sears ' Category: Saw ' Size: 5.68 MB. Table of Contents.
6/13/2025 5:01:04 AM • Saws • Answered on Jun 13, 2025
Milwaukee tools Milwaukee 0719-22 M28 Lithium-Ion Cordless Sawzall 1 Bat Logo
1 questions posted
Top Milwaukee tools Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
john h
Repair Ahjoshe
Are you a Milwaukee tools Saw Expert? Answer questions, earn points and help others
View Most Popular
  • Milwaukee tools Saws
Most Popular Question
lack cutting power 28 volt milwaukee
  • Saws
