20 Most Recent Dometic 457915 Duo Therm Brisk Air Conditioner Questions & Answers
2answers
Does not blow air through ducting
sounds like duct damage or restriction in duct work.
12/14/2022 10:39:28 AM • Dometic 457915... • Answered on Dec 14, 2022
How do you remove the inside cover on a roof mount
have to go through return air opening.
3/13/2016 5:36:55 AM • Dometic 457915... • Answered on Mar 13, 2016
Ac comes on when heater is on
board or cable issue between thermostat and board.
8/16/2015 10:46:31 AM • Dometic 457915... • Answered on Aug 16, 2015
Where can i find a relay for duo therm ac
http://www.dyersonline.com/rv-appliances/air-conditioners/air-conditioner-parts.html?limit=all Here a link to parts online not sure which relay you needed.
8/22/2014 7:57:48 PM • Dometic 457915... • Answered on Aug 22, 2014
0answers
My RV ac compressor starts, i min. Later it stops.
Low freon causes short cycling
8/5/2014 10:15:52 AM • Dometic 457915... • Answered on Aug 05, 2014
What is wrong with my RV ac unit ?
Low freon switch prevent the compressor from running when there is not enough freon to carry the oil to lubricate it. There is almost always enough pressure to start it but as soon as it's running low pressure drops and the compressor stops.
8/5/2014 10:12:58 AM • Dometic 457915... • Answered on Aug 05, 2014
Why is my Dometic Brisk Air air conditioner not working?
Sounds like the compressor is seized up and the smell is from the clutch slipping when it tries to engage. If that is the case, you need a new compressor at a minimum.
8/5/2014 3:45:48 AM • Dometic 457915... • Answered on Aug 05, 2014
0answers
User manual
Be the first to answer 9/10/2013 4:01:57 AM • Dometic 457915... • Posted on Sep 10, 2013Be the first to answer
Dometic ac roof model SL135RB I would like to order a new blower motor and start capacitor. I cannot find the correct swap
I would try a dealership; https://www.thedometiccentre.co.uk/dometic-spare-parts.html?SID=mb6g8spulubsjs363g5bn8uah3&brand=327&cat=129%2C393%2C2827%2C2843%2C2025&dir=desc&group_class=1157&order=rank
8/5/2024 7:00:58 AM • Dometic Heating... • Answered on Aug 05, 2024
Replacing a duotherm 3105058 thermostat
I was replacing a DUO-Therm 3105058 Rev A. very old Thermostat in a Coachman RV with 3106995.032 from Amazon. After looking all the information on the directions it was clear I would have to play a hit or miss on some of the wiring. Instead of using the same coding, such as RC, RH, G, Yellow and such. they used the function and I had to guess at some.Here is the wiring I found worked:There are 6 wires. One set of two wires (white On the W & red on the RH) and the set of 4 (yellow On the Y, green on the G, red on the RC and blue on the H). So to keep it simple the red on the RH went to the +7.5. The White on the W went to the FUR. HS/HP not used. the Yellow from the Y went on the cool. The green on the G went to the fan. The red on RC went to GND. and the Blue on H went to Hi fan.So red (RH) of the 2 wire goes to +7.5White (W) of the 2 wire goes to FUR.Yellow (Y) to coolGreen (G) to fanOrange or red from the RC lug goes to GNDBlue (H) goes to Hi Fan
12/7/2023 12:23:48 AM • Dometic Heating... • Answered on Dec 07, 2023
3answers
What causes the breaker to trip on a 2006 dura-therm dometic rooftop unit 13,500 BTU
check amp draw either bad compressor or fan motor
10/23/2023 12:10:49 AM • Dometic Heating... • Answered on Oct 23, 2023
Dometic 3107612.008 manual thermostat will cool but not heat.
possible heating element bad
8/31/2022 6:29:12 AM • Dometic Heating... • Answered on Aug 31, 2022
Dometic B2200. Compressor don't stopp
check compressor relay possible stuck on
8/19/2022 3:58:09 AM • Dometic Heating... • Answered on Aug 19, 2022
Dometic duo-therm 15K BTU 630516.331; compressor does not start, but the fans work in both high and low speeds
make sure thermostat on auto possible start up capacitor on compressor
8/6/2022 5:12:30 AM • Dometic Heating... • Answered on Aug 06, 2022
Dometic 457915 Duo Therm Brisk Air Conditioner Logo
Popular Tags
13 questions posted
Top Dometic Heating & Cooling Experts
jdthefixer
Ngoro
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Dometic Heating & Cooling
Most Popular Question
not blow air ducting
  • Heating & Cooling
