20 Most Recent U-Line Icemaker Questions & Answers
Telefunken Water Cooler & Ice Maker (TIM-03A). Good day, I need a manual for my Telefunken TIM 03A please. I cannot find it online.
No, there is no manual online for it.https://www.google.com/search?q=%22TIM+03A%22+manualContact them in the country where you purchased it. This is not a North American brand where we are located.https://www.google.com/search?q=Telefunken+manual..
1/28/2025 5:41:39 PM • U-Line Icemaker • Answered on Jan 28, 2025
U-Line Echelon CLR2060 Ice machine doesnt harvest properly
No where can I find anyone who has solved Uline Echelon ice maker harvesting issues. My Clr 2060 only now produces 1" solid slabs. In harvesting cycle, will not release individual cubes. Anyone fix this problem? vlog
6/4/2023 5:34:55 PM • U-Line Icemaker • Answered on Jun 04, 2023
2answers
Cubes in icemaker freeze but will not eject from maker
The mold heater is bad on this unit.
10/22/2022 4:44:49 PM • U-Line Icemaker • Answered on Oct 22, 2022
2answers
How to install an icemaker water supply line over concrete floor?
IM USE A 1/4 INCH WATER LINE LOOK FOR A SINK OR WASHER CLOUSE BY AND ATACH TO THE HOT WATER LIND IF YOU HAVE LIME IN YOUR STATE IF NOT USE THE COLD WATER RUNTHE HOSE INSIDE THE CAVINET TO HIDE THE HOSE.
9/28/2022 7:37:04 PM • U-Line Icemaker • Answered on Sep 28, 2022
3answers
U-line CLR2160 won't go into clean cycle. I hold the power button while pressing the light button 3 times.
I had to hold Power for 10+ seconds (until last "F" flashes, quickly let go of Power, then press and hold it again and while holding it pres the light three times.The process doesn't follow the manual's instructions at all. Their older model units with the physical on/off/clean selector switch was much more reliable than their new 2160 with touch screen controls!
9/19/2022 11:40:44 AM • U-Line Icemaker • Answered on Sep 19, 2022
BCM 95. Why is there no condenser fan or compressor activation when turned on?
because it is an automatic machine
3/24/2021 7:33:17 PM • U-Line Icemaker • Answered on Mar 24, 2021
2answers
After a power outage the ice maker stopped
Tell him to first fill ref-regent gas in compressor cause if does not have enough the comp will over heat a cut of .
7/26/2020 4:49:30 AM • U-Line Icemaker • Answered on Jul 26, 2020
0answers
0answers
Error code P1
Be the first to answer 8/15/2017 3:30:04 AM • U-Line Icemaker • Posted on Aug 15, 2017Be the first to answer
I have a Uline model SP18 ice maker.Recently the
It does sound as if you may need a new ice maker. Other than that does the compressor come on to keep the ice cold? If so is it making any type of noises beyond the typical hum?
6/10/2017 7:46:33 PM • U-Line Icemaker • Answered on Jun 10, 2017
Purchased magic chef counter top
Sorry we do not sell this product or any other. Please contact the manufacturer.
4/21/2017 5:46:52 PM • U-Line Icemaker • Answered on Apr 21, 2017
I HAVE A 2 YR OLD U-LINE ICE MAKER MODEL B12115 TH...
Follow this link. This should help with your uline not making Ice. line ice maker model ULN B12115 not making ice
8/1/2016 12:54:29 AM • U-Line Icemaker • Answered on Aug 01, 2016
0answers
0answers
U line ice maker is overflowing water
This is usually caused by a bad water inlet valve. This part is usually found behind the fridge at the bottom behind a panel on the fridge itself. It has 1-2 water lines running into it and 1-2 wire harnesses connected. You need to turn off the water going into the fridge and cut the power to the fridge to access this part. You can buy a new one at a local appliance parts store or online. If you need further help, I’m available over the phone at https://www.6ya.com/expert/rick_b814bade9ade93ea
4/19/2016 4:45:00 PM • U-Line Icemaker • Answered on Apr 19, 2016
My BI95 ice maker freezes and has water flow, the mould maker fills, the water continues to run into the bucket and it freezes solid. I changed the mould maker and water valve. The problem remains
If water keeps running after the fill cycle is usually indicates a bad fridge inlet valve. This valve controls the amount of water going into your icemaker. It is found where the water line goes into the fridge, usually in the back of the fridge at the bottom. You would need to cut the power to the fridge, turn off the water supply going into the fridge and remove a panel to get to it. You can check out online what a fridge water inlet valve looks like so you can identify it. It usually has 1-2 water lines going into it and 1-2 wire harnesses attached. You can buy new ones at a appliance parts store or online. If you need further help, I’m available over the phone at https://www.6ya.com/expert/rick_b814bade9ade93ea
4/19/2016 4:40:10 PM • U-Line Icemaker • Answered on Apr 19, 2016
Water in back of ice tube and in with ice cubes freezes
leaking water tray or water level to high check for any cracks and check water level after first harvest
2/3/2016 8:04:31 PM • U-Line Icemaker • Answered on Feb 03, 2016
U-Line Icemaker Logo
490 questions posted
Top U-Line Kitchen Appliances - Others Experts
john h
Kirk Augustin
Kirk Augustin
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • U-Line Kitchen Appliances - Others
Most Popular Question
u line clr2160 go into clean cycle hold
  • Kitchen Appliances - Others
