20 Most Recent
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Questions & Answers
Bissel pro heat 2x wont spray any water
I had the exact same problem with my ProHeat 2. It would spray only through the hose attachment but not on the floor. Cleaning of the spray endings on the floor unit fixed my problem. Either soap deposits or dirt was clogging the spray endings. Here is what to do to clean up the spray endings:
1. Remove the water container from the bottom unit
2. Look up for two red plastic endings on the bottom unit
3. Using your fingers to clip sides of an ending, carefully remove it from its slot
4. Using pliers, release the clamp from plastic ending and remove the red plastic ending from the hose
5. Clean the ending
6. Put the ending back on the hose, slide clamp back on the ending
7. Insert the ending back in its slot
8. Repeat 3-7 for the other ending
That solved the problem for me!
Shampooer tank not working
Most times there is a problem with the cap and insert at the bottom of the tank, part #2036675. Either that or the tank isn't sitting flush and down all of the way, leaving a gap. If this is less then 1 year, then it is under warranty.
I have a Bissell proheat steam cleaner, the 9500
There is probably more gunk in there, the gunk can dry and break off in little shards which can get clogged up.
You can try putting straight vinegar in it, try running it through and let it sit in there for a while to see if it can help loosen up and flush out the gunk.
Bissell Big Green Carpet Cleaner has poor suction why?
Hello, this is Ava with Think Crucial.
Most of the time the reason why vacuum is not picking up is due to loss of suction. You may need to check for blockages of your wand and hose. Remove the wand and hose from your cleaner when checking for blockages and any damages. Make sure to turn off and unplug your vacuum from the power before doing this. You may need to refer to your User's Manual for instructions and guide.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
