20 Most Recent Ipcw Chevrolet S10 / S-pu 1998 1999 2000 2001 2002 2003 2004 Head Lamps Projector Clear Chevy Only-1 Pair Questions & Answers
Chevy s10 wont turn over. transmisson line burst. lost all oil. replaced line and topped up oil. put in new starter and still wont turn over. i am wondering if engine could be siezed?
I doubt if the engine is seized but with the loss of oil in the transmission it could be a seized bush/ bearing in the torque converter or input to the ransmission
2/19/2016 7:07:50 AM • Ipcw Chevrolet... • Answered on Feb 19, 2016
0answers
0answers
0answers
2002 Chevy S-10 Ran out of Transmission fluid. Put fluid back in but only go 15mph. Will Rev up to 6000 RPM when trying to drive. When problem started it did run hot.
I'd bet if you check the fluid level properly as Owner's manual or Repair manual requires (hot), go through gears, measure in drive but Emergency on or helper on the brakes. You will probably find fluid is still low. Screen in the transmission pan may be clogged due to the "abuse". But it may also be burned "toast" as some say. You probably? have a leak? or you haven't checked fluid consistently. Seals may be bad. Temporarily I believe Bars leak stop has a Transmission seal leak stop. Consider mileage, is it time to trade vs new or (very lightly) used transmission?May be best to find very lightly used engine and transmission as a unit. Change out would probably be easiest other than emissions connections and compatibility. How is the rest of the truck's condition? A lightly used comparable may be your best alternative. Do you have transmission fluid lines connecting to the radiator? Is the coolant "oil-ly"? You may have a leak in the radiator internal fluid cooler. If so you need a new radiator or install separate transmission fluid cooler.
3/9/2015 3:17:23 PM • Ipcw Chevrolet... • Answered on Mar 09, 2015
Abs and emergency brake light stay on my 2004 chevy s10
You probably need to have your ABS changed. When you go to stop your car does it activate the ABS (The brakes acts like your on a slippery surface when you go to stop even though the road is dry). The brake light I have know Ideal if that's related or not.
3/6/2015 5:44:49 AM • Ipcw Chevrolet... • Answered on Mar 06, 2015
2answers
Driving down the road at45 mph and truck died
Check fuel pressure. Sounds like pump went out. Also check alternater.
3/6/2015 5:13:51 AM • Ipcw Chevrolet... • Answered on Mar 06, 2015
Ipcw Chevrolet S10 / S-pu 1998 1999 2000 2001 2002 2003 2004 Head Lamps Projector Clear Chevy Only-1 Pair Logo
130 questions posted
Top Ipcw Office Equipment & Supplies Experts
Arnie Burke
Arnie Burke
Tim Hofstetter
Tim Hofstetter
Are you an Ipcw Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Ipcw Office Equipment & Supplies
Most Popular Question
auto wiring diagram
  • Office Equipment & Supplies
