20 Most Recent Royal Vacuums Royal M305G Deluxe Metal Attachment Kit for Royal Metal Uprights, 7 Hose, 2 Metal Extension Wands, Crevice Tool, Round Dusting Brush, 10" Floor Brush Questions & Answers
How do I dismantle a Whatshome vacuum cleaner please?
It appears there might be a slight mix-up in the name, as there is no major manufacturer called "Whatshome" that produces vacuum cleaners. If you are thinking of the direct-selling catalog brand Whatshome (known for their Mexican cookware and kitchen lines), they do not feature vacuums. [1]
6/29/2026 3:59:48 PM • Vacuums • Answered on Jun 29, 2026
How much importance should be given to carpet and home cleaning?
Carpet and home cleaning are actually very important, especially if you want to maintain a healthy and comfortable indoor environment.Carpets and rugs tend to collect dust, allergens, pet hair, and moisture over time, so regular cleaning can improve both hygiene and the overall appearance of your home.In many cases, professional carpet cleaning is worth trying before replacing the carpet completely. Deep cleaning can remove stains, odors, and embedded dirt, which may help extend the life of your carpets and rugs.Small damages such as loose edges, minor tears, or worn sections can often be repaired at a lower cost than full replacement.However, if the carpet has severe water damage, mold issues, heavy wear, or permanent stains, replacement may be the better long-term option. A lot depends on the age of the carpet and the condition of the fibers underneath.These days, many homeowners are also moving toward eco-friendly and natural flooring materials because they are easier to maintain and more sustainable.Products from companies working as a Biodegradable Mats Exporter India are gaining popularity internationally due to increased awareness about environmentally responsible home decor. One example is Elite Edge International, which focuses on eco-friendly mat and textile products from India for global markets.Regular maintenance and occasional deep cleaning can often add several more years to the life of carpets and rugs.Visit us at: https://www.eliteedgeinternational.com/
5/12/2026 7:49:05 AM • Vacuums • Answered on May 12, 2026
Mr Rug Doctor Pro stopped sucking, when I restart it sucks for a minute then stops again, is there a diaphragm or something blocking it that I can just remove so I get continual sucking???
Nah, there's no diaphragm you can just yank out to fix it - that stop/start sucking is usually the machine protecting itself or getting blocked. The Rug Doctor Pro has a few common choke points that cause exactly what you're describing: sucks for ?1 min, then dies. *Check these 4 things first - 90% of the time it's one of them:* *1. Float shut-off triggered* Inside the dirty water tank there's a plastic float ball. When water gets too high or foams up, the float rises and blocks suction so you don't flood the motor. - *Fix*: Empty the tank even if it looks half full. If you used too much soap, foam trips it early. Add 1 cap of defoamer or a splash of white vinegar to the dirty tank to kill foam. *2. Clogged hose or dome filter* The machine will run, then overheat/clog and suction cuts out. - *Fix*: - Take the dome lid off the dirty tank. Under it is a foam filter/screen - rinse it clean. - Disconnect the hose from the machine and drop a coin through. If it doesn't fall out the other end, you've got a clog. Flush with hot water or use a broom handle to push it out. - Check the clear nozzle at the floor tool for hair/gunk. *3. Motor overheating ? thermal cut-off* Rug Doctors have a thermal switch. If airflow is blocked, motor gets hot, shuts down for ?15 min, then restarts. That matches your "works for a minute then stops" pattern. - *Fix*: Clean ALL filters, make sure tanks are seated tight so there's no air leak. Let it cool 30 min and try with just water, no soap. *4. Cracked or loose tank/gaskets* If the dirty tank or dome isn't sealing, you lose suction. The motor runs but it "stops sucking" because air leaks in. - *Fix*: Check the big rubber gasket under the dome lid. Check that both tanks click in solid. Any cracks in the tank = replace it. *There IS a "diaphragm" but don't remove it* The Pro has a shut-off valve/float assembly in the dirty tank lid. It's not meant to be removed. If you pull it, you'll suck water straight into the motor and kill it. $200 mistake. *Quick test to isolate it:* 1. Empty both tanks. 2. Take the hose off the front of the machine. 3. Turn it on and put your hand over the circular vacuum port where the hose connects. - *Strong suction that stays on* = your hose/floor tool is clogged. - *Still cuts out after 1 min* = internal clog or motor issue. If you've cleaned everything and it still cuts out, the motor or thermal switch is likely going bad. Rug Doctor's parts diagram doesn't list a user-serviceable diaphragm. Try the foam filter + hose flush first.
5/6/2026 10:08:17 AM • Vacuums • Answered on May 06, 2026
Need instruction booklet for pullman
Model SC360L
5/4/2026 4:00:51 AM • Vacuums • Answered on May 04, 2026
5answers
How do I remove a hardwood floor polish safely from a laminate floor
www.hard-wood-floor-cleaners.com and select the best chemicals and use for your hardwood polish laminate flooring.God bless you
4/21/2026 6:13:49 PM • Vacuums • Answered on Apr 21, 2026
Why does my Tzora scooter stop suddenly
Tzora mobility scooter, EV. ??? no model told just makers name (sad) the battery is dead, or lugs loose and or rusty. clean them charge the battery if it will not pass a load test the battery is toast, lost them manual for it , right here is one. https://www.manualslib.com/manual/804319/Tzora-Titan.html?page=24&term=trouble&selected=1#manual titan wild guess. page 24 read what to do .
7/12/2025 1:11:54 PM • Vacuums • Answered on Jul 12, 2025
My Bissel pro heat 2 the brushes spin while the handle is in the upright position when on floor or carpet. won't spin on carpet when reclined.Belt is new.
Could be a loose wire connection a faulty brush roll or a blockage
4/7/2025 12:00:08 AM • Vacuums • Answered on Apr 07, 2025
How do i remove the old swivel Cone Head assembly from my XtremepowerUS??
Turn off and unplug the vacuum: Remove the hose: Detach the hose from the vacuum body. Locate the screws: Find the screws that secure the swivel cone head assembly to the vacuum. These are usually located around the base of the assembly. Unscrew the assembly: Use a screwdriver to carefully remove the screws. Keep the screws in a safe place as you will need them to attach the new assembly. Detach the old assembly: Gently pull the old swivel cone head assembly away from the vacuum. If it is stuck, you may need to wiggle it slightly to loosen it. Install the new assembly: Align the new swivel cone head assembly with the vacuum and secure it in place using the screws you removed earlier.
1/27/2025 4:01:12 AM • Vacuums • Answered on Jan 27, 2025
Durabrand Vacuum HVC-22. Is there a manual to download please? It wasn't in the box.
Question edited for clarity.Question moved from Misc to vacuum cleaners.Unfortunately not manuals online, just a review.https://www.reviewstream.com/reviews/?p=55379The company are not known for vacuum cleaners, but consumer electronics.https://www.google.com/search?q=Durabrand+HVC-22+manual..
1/25/2025 5:56:28 PM • Vacuums • Answered on Jan 25, 2025
Miele S7000 won't stand upright?
Old Question! Here is a video of a full strip down of a Miele 7 Series .Why Won't My S7/U1 Stay Upright? https://www.justanswer.com/small-appliance/qdzqb-s7-u1-won-t-stay-upright-position-two-weeks-not.html If your Miele S7/U1 vacuum cleaner won't stay in the upright position, the problem is likely related to the upright locking mechanism or pivot point.
1/23/2025 6:46:08 PM • Vacuums • Answered on Jan 23, 2025
I would like to see what parts connect where on my Pensare hand held vacuum please?
Question edited into written English. Question moved from Misc category. This is not a good make. https://www.google.com/search?q=%22Pensare%22+hand+held+vacuum+manual ..
1/18/2025 5:47:46 AM • Vacuums • Answered on Jan 18, 2025
2answers
The brush on my stick vacuum cleaner won't turn?
Full 'make model (what is is)' in all questions first 3 words please. Can you hear the motor running? Broken drive belt. No noise, bad wiring connection / plug, failed motor...
1/9/2025 9:32:13 PM • Vacuums • Answered on Jan 09, 2025
2answers
Change direction of rotation?
Sometimes it's within the light housing. Other times it's actually a procedure you have to follow with the remote. I have added a video to explain.
12/26/2024 2:21:42 AM • Vacuums • Answered on Dec 26, 2024
Fantom twister vacuum - Took off the bottom plate to fix the wheel and I can't seem to get all the pieces to align to screw back in and I have an extra part. A curved piece of plastic that is loose.
Question edited for clarity, spelling, CAPS and punctuation. Question moved from Misc category to Vacuums. Normally the way to solve a question like this is to find a Parts Diagram. https://www.google.com/search?q=Fantom+twister+vacuum+parts+diagram Or you find a video from someone that has done it. https://www.google.com/search?q=fantom+twister+vacuum+replace+wheel But this is not a popular make and seems to have very little support. ..
10/29/2024 3:24:56 AM • Vacuums • Answered on Oct 29, 2024
Where can I get a manual for an anex hand vacuum
https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.manualslib.com%2Fmanual%2F1048978%2FAnex-Ag-2095.html&psig=AOvVaw3eA0uKwvLCZq8eeZlVdJZv&ust=1725175832807000&source=images&cd=vfe&opi=89978449&ved=0CAYQrpoMahcKEwiYtp772p6IAxUAAAAAHQAAAAAQBA
8/31/2024 7:31:33 AM • Vacuums • Answered on Aug 31, 2024
Royal Vacuums Royal M305G Deluxe Metal Attachment Kit for Royal Metal Uprights, 7 Hose, 2 Metal Extension Wands, Crevice Tool, Round Dusting Brush, 10" Floor Brush Logo
2 questions posted
Top Royal Vacuums Vacuums Experts
AskDyson
AskDyson
ADMIN Andrew
ADMIN Andrew
Are you a Royal Vacuums Vacuum Expert? Answer questions, earn points and help others
View Most Popular
  • Royal Vacuums Vacuums
Most Popular Question
help royal metal upright vacuum cleaner
  • Vacuums
