) to turn off the product.
2. Disconnectthe USB cable from the rear of the product.
3. Disconnectthe power cord from the rear of the product.
4. Pressin the tab on the left side of the rear door to release the door. Remove thedoor by pulling it away from the HP All-in-One.
Figure 1: Press the left side tab torelease the rear access door
Gently remove any jammed paper orbits of torn paper from the rollers inside the product. Use both hands to pullout any whole sheets of paper to avoid tearing them.
Take Note:
Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur.
Figure2: Remove scraps of paper
Replacethe rear access door. Gently push the door forward until it snaps into place.
Step three: Clear the jam from theautomatic document feeder (ADF)
1. Openthe cover of the ADF.
Figure 3: Open the cover of the ADF
1. Gentlypull the paper out of the rollers.
CAUTION:
If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If you do not remove all the pieces of paper from the product, more paper jams are likely to occur.
2. Closethe cover of the ADF.
Step four: Clear the jam from thefront of the product
1. Lookinside the product through the paper output tray to check if any loose or tornpaper is stuck in the rollers.
2. Gentlypull the paper out of the rollers.
You must Remove paper from the front of the product as carefully as possible. If any torn pieces of paper remain inside the product, more paper jams are likely to occur, and this could damage the print mechanism. Use a flashlight to make sure that you find all traces of paper.
3. Reconnectthe power cord to the rear of the product.
4. Pressthe Power button (
) to turn on the product.
Step five: Print a self-test report
Printa self-test report. Please inform me if this help you with the paper jamproblem.
HP J3680 Officejet All In One... • Uploaded on Feb 16, 2018
370 questions posted
2,817 Questions
1,584 Questions
1,223 Questions
991 Questions
857 Questions
