20 Most Recent
Coleman 10' X 10' Sundome Tent 9160K101 Questions & Answers
How to install batteries in coleman axis headlamp
Side panel comes out by turning (if you look on head strap, one of the ends says Key/battery. You can insert that into the side battery compartment and turn counter-clockwise). After you have that cover off, simply take something like your knife and pry it from behind the battery case and it will slide right out.
(O) is what you will see if you're looking down on it. The circle in the middle should have 3 tiny screws in it. Stick your knife between the O and the ) and pry the O out. Hopefully that makes sense. You could also just pop the battery cover off, and then hit the flashlight into your hand so that you knock the battery compartment loose. Then you don't have to pry anything. But that might damage the LED...probably not though.
Have used 1981 Coleman pop-up camper and the
My Coleman has the same problem. I can crank the top up but it will not hold in place.
I just leave the crank handle in place after raising the top and secure the handle to the bumper with a bungee cord. It's jury rigged but it works great.
I purchased a camp trailer
go to the Coleman web page and down load a user manual for that model
or simply talk to a Coleman tech representative to get the info
I have had two small Coleman 'Frontier PZ' propane
there is something in the jets or the piping to the mantels, you my find spider webing there, if you did no cap the port where the tank goes some small friends might have wanted to go camping with you.
How to light coleman lantern
Kerosene lanterns require a little more than just lighting the mantles. Go to Coleman's website and find the directions (for free) for KEROSENE lanterns. The generator on the lantern needs to be preheated with alcohol before it will actually light. Make sure lantern is a Kerosene lantern and not a white gas (Coleman fuel) type, there is a difference even though they look similar.
Coleman multi maxi bar can
Usual problems are:-
No gas from supply cylinder.
Safety bypass not allowing start up gas flow.
Piezo lighter not sparking.
Another possibility, strange as it mat sound, is the burner being blocked by mud-wasps; difficult to believe, easy to rectify.
I have a Coleman model FL 28-R electric fireplace,
There is a fuse located over the heating element in front of the fan.
It sits over a small slot above the heating element (probably to cause
it to stop working by design). Yes I'm a pessimist. It can be bypassed
if it is an emergency by wiring across it. I'm trying to find the
replacement fuse now (10amp jet 250v #00575) If you find it please send
info to warfalcon23@Gmail.com. I hope we all get our heaters working,
for $250 + dollars you'd expect it to last longer than 1 month.
Battery won't charge on 1million candlelight spotlight pml9000
Replace the battery, Lowes sells the sealed lead battery's for $14.95. Check in the section they sell 'EXIT' signs the battery number you will be looking for is #30128 made by Utilitech. Step 1. Unlock the bulb careful not to pull too hard to prevent snapping off the ground wire for the bulb and unplug the 'black' and the 'red' wire from the battery terminals.Step 2. Locate the 2 screws on the side in the grey area use a P1 Phillips screwdriver a P2 will not fit. Step 3. Carefully pry the 2 half's apart dont pull too hard but just enough to allow the battery to slide out.Repeat the process in reverse to install the new battery.
