20 Most Recent Mantis 4-Cycle Tiller Questions & Answers
2answers
Mantis 4 cycle (brand new): oil leaking out, smoking soaking air cleaner, quits running..
Sounds like your gas tank is not breathing properly. try this: the next time you run the tiller and it begins to stall out, try loosening the gas cap. It should start running again. This means that the gas cap is clogged. Unclog it or purchase another one.
Jim
5/14/2018 8:03:19 PM • Mantis 4-Cycle... • Answered on May 14, 2018
manual
Why is oil leaking from cylinder
-Oil is over fill. Good luck Mai
8/29/2014 9:02:12 PM • Mantis 4-Cycle... • Answered on Aug 29, 2014
I added to much oil it leaked out of the carb now when I strat it up it smokes white smoke for a minute then stops and runs fine
If you are concerned, you can remove some of the oil. Place a pan under the mower and loosen the oil pan bolt but do not remove it completely. Drain a few ounces of oil out and then tighten it up. Be sure to take the wire off the spark plug before you do this. The lower oil level should stop the smoking.
5/19/2014 12:21:44 AM • Mantis 4-Cycle... • Answered on May 19, 2014
0answers
Won't start
Be the first to answer 4/14/2014 3:20:30 AM • Mantis 4-Cycle... • Posted on Apr 14, 2014Be the first to answer
Where is the spark plug located won't start
Try looking for the plug wire and follow it in. Should be coming out of the flywheel shroud on top of the engine. Good luck.
12/14/2013 11:16:18 PM • Mantis 4-Cycle... • Answered on Dec 14, 2013
2answers
How do I check the oil on my Mantis Tiller with 4
Tip the unit up with the front on the ground, the dip stick will be on the lower part of the engine & comming out at an angle
6/22/2013 10:03:19 PM • Mantis 4-Cycle... • Answered on Jun 22, 2013
Mantis 4-Cycle Tiller Logo
Popular Tags
62 questions posted
Top Mantis Garden Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Mantis Garden Expert? Answer questions, earn points and help others
View Most Popular
Mantis Garden
  • Mantis Garden
Most Popular Question
find
  • Garden
