Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
Posted on Sep 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code f13
How do i repair this fault
  • 1 more comment
  • swats11 Sep 28, 2008
    everytime i switch dryer on,it works for some time and then cuts power of my whole flat and f-13 error is seen on screen which cannot be stopped for some time and it does not complete drying cycle and does not allow us to switch m/c off.
    even if we try it comes on again and trips power off everytime we try.my washer/dryer is not even 1 yr old.pls suggest sol
  • Anonymous Feb 10, 2009
    I have same prob goin to phone hotpoint. Apparently the thermostat is gone it happens all the time according to online forums
  • samkebab Feb 23, 2009
    I have an f13 fault.. can anyone recommend how to fix this?
Dai Boyce
Level 2:
Sergeant:
  • Expert 288 Answers
  • Posted on Nov 15, 2014
Dai Boyce
Expert
Level 2:
Sergeant:
Answers
288
Questions
Helped
160911
Points
858
There is a small thermostat button ontop of the Heater mechanism which has tripped . It has either a red dot or blue dot ontop. Use a pin or opened up paper clip and push through the red wax. It will go click and it is reset. .
It sometimes trips out with a F code which normally trips the machine off because it thinks the Heater unit is on fire.
There is a small disk which costs about £15 to buy which you can change. You will need HEX screwdriver set to change and open up the Heater matrisx to clean the fluff off the element.
A
Anonymous
Can't comment on tripping your power but see posts on this sight for Hotpoint WD860 for F-13 solutions.
...also if it's less than a year old then you're still in the warranty period I believe. Perhaps you can get Hotpoint to fix this?
1 Related Answer
Anonymous
  • 1294 Answers
  • Posted on Sep 03, 2007
SOURCE: machine fault code "f13"
Plug off the wall. There is a thin rubber tube going from the switch area to the exit near the outlet tube. Probably this is blocked. This tube should be free from any blockage; take out the top clip from this tube and blow into it - it should be free, clear the blockage if any and refit. This is the water level tube which tells the machine when to switch off water, etc.....
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
