Texas Instruments TI-30XA Calculator Logo
Posted on Sep 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i type a problem with parentheses? - Texas Instruments TI-30XA Calculator
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Texas Instru... Master 102,366 Answers
  • Posted on Sep 24, 2011
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10724326
Points
622696
Use the parentheses keys, located just above the 8 and 9 keys, to type parentheses.
2answers
How to type a negative exponet
The same way you type in any negative number. Press the (-) key then enter the digits.
2answers
Where does the parentheses go on this problem 16-5x2-2=20
pemdas, parentheses,exponent,multiply,divide,add,subtract. best I can do been out of school for awhile! Hope it helps.
How to enter two sets of parentheses
Just use the same parentheses keys. The 30Xa will let you nest up to fifteen sets of parentheses.
Why no parentheses in the following 1/ squareroot of 1/15^2 + 1/20^2 on any other calculator parentheses are needed in excess.
Contrary to what you may be thinking, parentheses are necessary to ensure that calculations are performed as intended. If you were using stacked fractions that may lift some ambiguities, but since you are not using parentheses anything goes.
Here is one interpretation of the expression. I am quite sure you will not be able to find it without inserting the necessary parentheses.
Argument must be a list
You are trying to use a command or a function that requires you to give it some information to use. The information required is supplied between parentheses. What is inside the parentheses is called the argument(s). Each argument must have a certain type of data : scalar, vector, list, matrix. It happens that one of the arguments in your command or function must be of type list. Before calling the function you must have defined (created) that particular list and populated it with necessary values.
That is all I can say, because I have no idea what you are trying to do.
2answers
How to solve foil method
The FOIL Method is a process used in algebra to multiply two binomials. The lesson on the Distributive Property, explained how to multiply a monomial or a single term such as 7 by a binomial such as (4 + 9x).
1.gif But, what if there was a binomial instead of a single term outside of the parentheses? That is, what if a binomial was being multiplied by another binomial? An example of this is given below.
FOIL stands for:
First - Multiply the first term in each set of parentheses Outer - Multiply the outer term in each set of parentheses Inner - Multiply the inner term in each set of parentheses Last - Multiply the last term in each set of parentheses Now let's give it a try in our problem. We'll start by multiplying the first term in each set of parentheses and then marking down the answer below the problem.
3.gif Now we will multiply the outer terms and again mark down the answer below the problem.
4.gif And the Inners.
5.gif And finally the last terms.
1helpful
How do u do fractions
To do fractions on the TI-83, you must use parentheses.
The parentheses buttons (there are two of them, facing either way) are near the upper right corner of the buttons on the calculator.
To write a fraction, you must enclose it in parentheses, using the divide button (the slash) as the fraction sign (the line between the numerator and the denominator)
For example, this would be one half:
(1/2)
And this would be one third:
(1/3)
As long as the numbers are confined between parentheses, with no other numbers in there besides the fraction, they will act as a single group.
Don't ever be afraid to use plenty of parentheses, either!
For example, if you wanted to add one half to one third, and then multiply it all by three, the following would definitely be acceptable:
((1/2)+(1/3))*3
When I'm adding component vectors, how do I get the number for 20SIN170(degrees)?
If the default angle unit is not degree, you must set it to degree by pressing the [DRG] key. Once this is done you type
170 [SIN] [ * ]20 [ENTER]
If it feels awkward to enter the command this way you must insert parentheses to make sure calculator is evaluating the sine of 170 , not the sine of 20*170
20 [*] [( ] 170 [SIN] [)] [ENTER]
Notice that the parentheses enclose 170 [SIN]. The sine of 170 will be computed first, then the result is multiplied by 20.
Hope it helps.
Thank you for rating this solution.
3helpful
3answers
Top Texas Instruments Office Equipment & Supplies Experts
Rommel Balcita
Paul Bade
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
