New Kyocera FS-1135MFP, on power up it says "Developer unit not installed"'. Reinstall of all units and install of new units from maintenance kit don't make any difference. Any help?
SOURCE: New maintenance kit
Hi Did you run up the developer unit? Menu button down to Other then to Service and press enter on developer and switch off and turn on will run for a while. In the service menu after you run up the dev unit you may have a option in there to press enter on the MK Symbol.
Cheers
SOURCE: Ricoh ap4510 - Maintenance Kit Issue
For the message to be cleared you should enter the service menu and reset the replaced elements
SOURCE: Kyocera FS-3900 and FS-4000 Prints very faint. New printers affected
sounds good
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Hi not sure if you tried this...
It can also be that your toner cartridge is empty
Try inserting a new toner
I get this a lot with toner cartridge being empty on 1135/3514
