Computers & Internet Logo
Anonymous Posted on May 31, 2012
Cpu My problem is my cpu i try to turn it on when boot bois dsplay den it off agen why sir my model cpu. Pentium(R) D cpu 2.8ghz dualcore 1gb of ram ecs p4m 800-m7 (motherbord) 40g of hardisk gforce 5500 videocard windows XP (OS) thanks for anser...!
General Systems Consulting
Level 3:
Top Expert:
  • Master 5,051 Answers
  • Posted on Jun 01, 2012
Master
Level 3:
Top Expert:
Answers
5051
Questions
0
Helped
1081122
Points
15385
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
5 Related Answers
Adnan Manzoor
  • 102 Answers
  • Posted on Dec 07, 2007
SOURCE: Upgrading a processor....
troncho81:
Compatibility: make sure that your motherboard supports the new CPU you have bought. If you are sure it supports it then make sure you have the latest BIOS or any firmware from manufacturer installed.
I am assuming that you have seated the processor properly and it also has a fan properly working over it.
Hope that helped!
Anonymous
  • 175 Answers
  • Posted on Nov 08, 2008
SOURCE: p4m800-m7 Rev:3.1 RAM PROBLEM!
the problem is with the new ram.
its phsically damged.
may be little bit that you cant see it.
try checking the other 1GB ram.
A
Anonymous
  • Posted on Dec 01, 2008
SOURCE: sir i m getting a
you have to do exactly what the system is saying Your CPU fan connector is loose or there is a problem with your CPU fan if You are well-versed with the hardware part of the system you can do it yourself Or call Your PC administrator or who repair Your PC
Josh kuzma
  • Posted on May 04, 2009
SOURCE: no boot up / no post for new CPU (ECS G31R-M7) with Intel E5200
i have a ecs g31t-m with a pentium e5200 dual core. i bought the board from ebay and the bios needed to be flashed before it would reconize the processor. after flashing the bios i still had the same problem. i found that in the user manual there is a list of "qualified" ram. before looking at this list i tried some ram that was not on the list and it wouldn't boot. after changing the ram to one that was on the list it finally booted up. however, after getting it to boot and reloading win xp, i cant get any drivers to load for the onboard equipment. so now i'm stuck. i hope this helps and if someone can give me direction on the drivers i'd be in good shape.
Alun Cox
  • 2679 Answers
  • Posted on May 08, 2010
SOURCE: i have d101ggc motherbord with pentium(R)D cpu
No reason why not.
Top Dual Computers & Internet Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you a Dual Computer and Internet Expert? Answer questions, earn points and help others
