Sewing Machines Logo
Anonymous Posted on Jun 29, 2012
Threading a bernina
Please tell me step by step
Rick Beament
Level 2:
Novelist:
  • Sewing Machines Expert 166 Answers
  • Posted on Aug 28, 2012
Rick Beament
Level 2:
Novelist:
Answers
166
Questions
Helped
76668
Points
204
Depends on the model, for detail but basically: Ensure the takeup arm / needle is at the top of its motion - with electronic models this is easiest done just by 'blipping' the foot controller and the needle will automatically return to top. Put your spool of thread on the spool pin. On older models with the vertical spool pins ALWAYS use a felt pad underneath to prevent the spool spinning when the thread is drawn off. On later models with a horizontal spool pin, hold the spool in place with the correct size retainer, with the larger diameter facing away from the spool. Make sure the foot is up (this is important). Draw thread off the spool and route it through the pre-tensioner on the back of the machine, then through the slot until it passes through the tension discs next to the tension control. The thread is then brought down the right-hand-side of the takeup arm cover, and pulled-up the left-hand side (it should be pulled into the check spring at the bottom, automatically. Pass the thread around the right-hand-side of the takeup arm and then the left-hand-side so that the thread is left running through the takeup arm. Drop the presser foot. Route the thread behind the lower thread guide at the bottom of the takeup arm cover and then through the thread guide at the bottom of the needle bar, just above where the screw that retains the needle is situated. The thread guide might be a simple loop of wire or a clip on the botom of the needle bar. Thread the thread through the eye of the needle either manually or using the needle threader, if fitted and off you go. It's important to have the foot raised when routing the thread through the upper tension discs to make sure the thread sits properly within the discs rather than just going over the top of them. Raising the foot holds the tension discs open.
1 Related Answer
Page Gettman
  • 30 Answers
  • Posted on Jun 21, 2009
SOURCE: How do you thread a bernina 1008?
I hope I can explain this in an understandable way!
1. Pull the end of the thread from the spool to the left and "click" it into the little metal guide (on the top of the machine) that is at the back of the long **** in the top. It's easiest to do this by holding the thread tight between your two hands, placing it behind the guide, and pulling forward until it clicks in.
2. for the remaining steps, let the thrread slide between the fingers of your right hand, keeping a little tension on it, as you thread the machine with your left hand.
3. Bring the thread end forward, laying the thread into the ****, and continue downward, along the right side of the vertical silver bar/hook thingy.
4. Bring the thread under that bar from right to left, and go back up towards the top of the wide **** in the front of the machine. As you pull up, the thread will click into the lower bar/hook thingy.
5. Lay the thread along the right side of the wide ****, go over the top of the needle bar (the part that goes up and down in the ****) and bring it down the left side. It will click into the needle bar.
6. Bring the thread back down towards the presser foot. Right in front of the screw that holds the foot on, there is a hook that opens on the left side. Slide the thread behind this hook, and then thread the needle from front to back.
7. Hold onto the end of the thread and run the needle down and back up once. Pull on the thread, and it will pull up a loop of the bobbin thread. Stick the tip of your scissors or seam ripper into the loop and pull the end of the bobbin thread out.
8. Slide your top thread through the slot in the presser foot so it comes out from underneath the foot, and you're ready to go! (Be sure and hold onto both threads for the first few stitches when you start a seam, to keep if from jamming up inside.)
Let me know if you need any clarification.
Top Sewing Machines Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you a Sewing Machine Expert? Answer questions, earn points and help others
