Watches Logo
Posted on Dec 20, 2008
How to set an invicta chronograph watch - Invicta Watches
  • Arturs Kalnins
    Arturs Kalnins May 11, 2010
    Wee need all details of watch: model, number etc. Then it may be poss to help.
  • Anonymous Mar 25, 2014
    Chronograph not working
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Dec 22, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1335
Points
I have the instructions
Invicta model 12983, how to set day on the subdial
View the instruction manuals - Invicta
invictawatch.com/service/view-the-instruction-manuals
Enter your 4 or 5 digit model number to locate your watch. RECEIVE THE NEWSLETTER SOCIAL MEDIA · Terms & Conditions Customer Service Service ...Missing: 12983 ‎subdial
Setting Time Date Invicta Watch Chronograph - SmartBargains
https://www.smartbargains.com/.../Setting-Invicta-Chronograph.html
Know how to set time, day, and date in the Invicta Watch Chronograph. ... Invicta sells several different kinds of chronograph watches, with the two main ... and the Invicta Big Date and Day chronograph - the subdials that measure seconds and ...Missing: 12983
Invicta Reserve 48mm Octane Swiss Made Quartz ...
1helpful
How it works invicta clock mechanism ?
Your watch is battery powered or a 'quartz' watch. It is commonly refered to as a 'chronograph'. That is another word for stop watch.As well as telling time and the date, your watch can time how long an event lasts. For example, a horse race. You start the chronograph or stop watch when the horse starts and stop it when it crosses the finish line. When the next horse starts you need set it back to zero to time the next race.Operation is simple. The upper push button starts and stops the chronograph. Try it. Now with the chronograph stopped, push the bottom button. The hand return to the 12 o'clock position or the 'zero' position. Also notice the small dials on the dial or face of the watch. They record minutes and other increments of time. The large hand going around when you push the upper button is recording seconds. Hope this helps, Michael
1helpful
Need a manual describing how to set the date for an Invicta Reserve Subaqua 6208
mcdevito75 here, Best Bet, online to shopnbc.com to Invicta watches, or give Invicta a call , info at the website at ShpNBC.com
1helpful
How do i set the day of the week on my Invicta subaqua noma 6125?
For Invicta chronographs to set the day you need to pull the crown out to position 3 (2nd click after releasing the crown/ furthest crown position/ same position to adjust time). You can only set the day by rotating the crown clockwise. Every 24 hours of clockwise rotation will move the day indicator forward 1 position (Mon>Tue, Tue>Wed, etc). If your watch is set one day ahead of the correct day (Its Tuesday but the watch displays Wednesday for example) you will need to rotate the crown clockwise through the entire remainder of the week in order to get to the correct day, you CANNOT rotate the crown counter-clockwise in order to move the indicator back a day.
4helpful
How do you set the correct day on a Invicta 5377
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all INVICTA watch manuals. Rate me, please.
Neeed manual for Invicta 4047 Atomic Watch
The Atomic watches set date & time automatically. The general instruction book applies to the alarm & chronograph features.
http://www.invictawatch.com/support_files/instruction_manual/Manual-HiRes.pdf
How do i set the time on an Invicta Lupah mens watch with three subdials
The Lupah has a chronograph so dont worry about the sub dials while your setting the time. Pull the crown out to the first position and set the time. For the date pull out to the second position and set the date.
To set the chronograph sweep arm pull the crown out and press and hold down the start button. The sweep arm will move into position. Stop it on the 12:00 or 0 position.
Two cheap chronograph watches that won't set date and month
I would need the models on all watches to answer this question. I would make sure that the crown really doesn't pull out to a second position. They can be a little stubborn sometimes.
Top Invicta Watches Experts
Ngoro
john h
Are you an Invicta Watch Expert? Answer questions, earn points and help others
