SOURCE: DIFERENT DISPLAY FOR THE SAME WATCH MODEL.
A watch is considered Swiss, when it is made in Switzerland (hope I spelled that right), by a Swiss Comapny, using 50% or more parts that are also Swiss. Watches made this way will have "Swiss Made" Swiss" or a similar print on the back.
If it has the lables of "Swiss movement" "Swiss Case" then it means that it is only partly swiss made, and will not have a lable listed in the first part of this solution branded on the back.
Hope I helped, have a great day.
SOURCE: I can't figure out how to adjust the offset chronograph
This is to adjust the seconds hand or minutes hand for the chronograph. Pull the crown out either one click or two ... depending on the models. Squeeze and hold the top and bottom buttons at the same time (timer stop and reset buttons). Hold down together for 2+ seconds. The chronograph hands should reset by spinning around and stopping at 0. If the don't stop right at zero, you can now adjust where they stop. Leave the crown where it is in that same position out. Press the top chronograph button and hold it down for fast movement or short presses for fine movement to adjust til it stops at the top. This will adjust where the seconds hand stops. Then click the bottom chrono button once. Repeat what you did with the top chrono button and it should allow you to fine tune the position for the next dial, and so on. When you are done, press the crown back in all the way to the normal position.
SOURCE: how do you set the alarm for the invicta reserve
After fooling arround I found out that if you pull the arm all the way out and reverse turning the alarm arm can be set. Thanks for your concern
