Nintendo Wii Console Logo
Posted on Jan 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is error code 220602 on the wii - Nintendo Wii Console
Anonymous
Level 1:
  • Contributor 57 Answers
  • Posted on Feb 22, 2009
Anonymous
Contributor
Level 1:
Answers
57
Questions
Helped
27946
Points
82
220602 means there is a problem with the internet settings.
when entering your setting use manual settings to set up. manually entering the DNS settings when the screen comes up.
(note: errror code 32002 means the same thing)
Anonymous
Level 2:
Scholar:
  • Expert 97 Answers
  • Posted on Jan 04, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
97
Questions
0
Helped
24654
Points
203
Nintendo has a site set up to help you with error codes.
http://www.nintendo.com/consumer/systems/wii/en_na/errors/index.jsp
The code you're giving is a DNS error. Check out their solutions here.
http://www.nintendo.com/consumer/systems/wii/en_na/errors/results.jsp?error_code=220602&system=Wii&locale=en_US&action2.x=21&action2.y=18
2 Related Answers
Anonymous
  • 38 Answers
  • Posted on May 07, 2008
SOURCE: wii connect 24
try to change your router's channel to either 1 or 11 and make sure your wii is close to the router with no interference from microwaves and such.or you can change the dns servers like switch around the secondary ip address to primary and primary ip address to secondary.also,try to set your router's broadcast setting to 'mixed'.no guarantees,hope this helps.
Anonymous
  • 644 Answers
  • Posted on Sep 30, 2010
SOURCE: error code: 220602
Goto this url should tell everything you want to know.
http://www.nintendo.com/consumer/systems/wii/en_na/errors/results.jsp?error_code=220602&system=Wii&locale=en_US&action2.x=19&action2.y=22
Error code 220602
Looks like you might need to set the DNS in the Wii to that of the router.
Cannot connect to Internet Error code 220602
Hello there!
There are a couple possible options to fix your problem that may work:
  • Temporarily disabling WEP encryption on the router.
  • Set up another internet connection profile on the Wii (w/o encryption key)
  • Select the User Agreement on the Wii.
  • Re-set the WEP encryption key on the router.
  • Switch back to the internet connection profile on the Wii (w/encryption).
I would try all of these and hopefully your problems will not persist. Good luck!
2answers
I have the code 220602 coming up on the wii and cant get online
Try these steps:
2answers
Trying to connect to internet and its reading error code 220602.
Sorry to hear your having issues with your wii internet. One solution you can try is to:
Disable encryption on your router. Set up a new wireless network profile on your wii and then connect to it and do not use encryption. Accept the user agreement when it pops up. Then set up the encryption again on your router and try to connect using the encryption key.
Wii will not connect to inernet with wii shopping channel even though it says connection successfful. error code 220602.
the answer is right here
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=220602&system=Wii&locale=lang
My wii has an error code of 220602, what to do?
These errors indicate a problem with the Internet Settings entered into the Wii. Try the following: Use the Manual Settings (rather than Search for an Access Point) to set up your Internet Settings on the Wii.
click here to download repair guide if u need
Cannot connect Wii to Linksys WRT160N, Test connection is successful; however getting error code 220602 when it attempts to access the internet. Tried changing channels, manually inputting codes, disabling...
1.Unplug all off your devices starting with the wii then your linksys router.
2. On the router unplug the connections on the back ports then reconnect them "port connections first then power connections second"
3. Go to the wireless connection screen and do a network test on the Wii.
4.If that doesn't work then you have to go into the router itself through its ip address and redo the settings to make sure you have the connection to the router unblocked.
I hope that helps
Rad
2answers
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
