Error code22062
SOURCE: what is error code 220602
220602 means there is a problem with the internet settings.
when entering your setting use manual settings to set up. manually entering the DNS settings when the screen comes up.
(note: errror code 32002 means the same thing)
SOURCE: error code: 220602
Goto this url should tell everything you want to know.
http://www.nintendo.com/consumer/systems/wii/en_na/errors/results.jsp?error_code=220602&system=Wii&locale=en_US&action2.x=19&action2.y=22
SOURCE: my wii has an error code of 220602, what to do?
These errors indicate a problem with the Internet Settings entered into the Wii. Try the following:
Use the Manual Settings (rather than Search for an Access Point) to set up your Internet Settings on the Wii.
click here to download repair guide if u need
SOURCE: Trying to connect to internet and its reading
Manually change your Wii console's DNS settings. To do this, follow these steps:
SOURCE: Cannot connect to Internet Error code 220602
Hello there!
There are a couple possible options to fix your problem that may work:
I would try all of these and hopefully your problems will not persist. Good luck!
