Computers & Internet Logo
bujji Posted on Sep 05, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i install Exceed got error message :"error 1317 :an error occured while attempting to create the directory c:/programdata/hummingbird/ connectivity/12.00/global/exceed". Suggest me how to solve this issue.
adam adms
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 829 Answers
  • Posted on Sep 05, 2013
adam adms
Master
Level 3:
Renaissance:
Answers
829
Questions
0
Helped
71975
Points
2201
To resolve this problem ensure that you have the necessary permissions on your hard disk or disks. To do this, follow these steps.
Note: because there are several versions of microsoft windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
1. In windows nt explorer, select the folder.
2. Right click the folder, then click Properties on the shortcut menu.
3. On the security tab, click permissions.
4. Select the "Everyone" group, then click "Full Control" in the Type of Access List.
5. Select the Replace Permissions on Subdirectories check box.
6. Click ok.
7. Click yes to the prompt confirming whehter you want to replace permissions on all subdirectories.
8. Click okay in the folder name properties dialog box (where folder name is the name of the folder that you selected in step 1).
9. Run Office set up.
4 Related Answers
Anonymous
  • 116 Answers
  • Posted on Feb 03, 2009
SOURCE: AGV 8 (build 233) Installation
Make sure all other antivirus software is removed before you try to install it.
Also, run a scan for existing infections with an online scan like TrendMicro = http://housecall.trendmicro.com or
Panda http://www.pandasecurity.com/activescan/index/?track=1&Lang=en-US&IdPais=63
Anonymous
  • 995 Answers
  • Posted on Nov 08, 2009
SOURCE: Error message when attempting to create a DVD
Try to burn your programs using a different burning software like nero or etc.
Anonymous
  • 129 Answers
  • Posted on Jul 28, 2011
SOURCE: i cant install exceed on
first make sure windows 7 is fully updated then goto add remove programs in the control panel and make sure it is not installed (humor me:) if it is uninstall it. then, i assume you are installing from a disc, put the disc in the drive but do not use the auto cue. instead goto my computer and right click on the cd drive and select open. then find the installer and right click on it. now select either run in compatibility mode(if it's there) or troubleshoot compatibility. hope this helps but if you have any more questions just ask:)
Anonymous
  • 32 Answers
  • Posted on Aug 04, 2011
SOURCE: The Windows Search service stopped working on my
Go to services and disabled it (and I had to also disable the automatic retry separately or it kept starting despite being "disabled"). Any attempt to manually start it there gives me:
Windows could not start the Windows Search service on Local Computer.
Error 1067: The process terminated unexpectedly.
The fix is to delete all files related to search indexing, located by default at:
C:\ProgramData\Microsoft\Search\Data\Applications\Windows
and:
C:\ProgramData\Microsoft\Search\Data\Temp
Note that these are both system directories - You can access it without changing your folder options, just type the shortcut to the folders in the address bar of windows explorer. Or if you want to show hidden folders, you go into Control Panel, (make sure you're in classic view) and you click on the icon labeled Folder Options, at which point you go into the View tab, there is a sub-folder about halfway down entitled Hidden Files and Folders, click the button next to Show Hidden Files and Folders.
Delete all files and folders in these directories.
Then, change the service back to starting automatically. You still can't start the service until you reboot, at which time Windows will rebuild the index for you.
If you are still not able to sort it out...then visit http://www.vtechsquad.com/ and get the best help possible.
Top Hummingbird Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Ciprian Ciolacu
Are you a Hummingbird Computer and Internet Expert? Answer questions, earn points and help others
