My Hitachi TOURO 1tb USB 3.0 External hardrive is not being reckonising by my computer, yet other computers pick it up. I really need to access it on this computer as it contains important documents
SOURCE: Maxtor Basics 1Tb external hard drive not working
option 01. try the unit on another windows pc. if its the same. i am afraid you might have an issue with the device.
option 2 . you could remover the **** from the enclosure & fix it directly to the pc so that you can retrive the data. however this will have an impact on your warranty
SOURCE: No power supply to NEW WD 1TB
SOURCE: Computer doesn't detect drive
Hello
I had this problem a few months ago and i fixed it by following this steps.
Go to control panel.
Administrative tools.
Computer managment.
Storage.
Disc management.
Right click on you drive in the chart
Click on change drive letter
Change
Restart your computer and it should work.
Please rate this.
Best regards
SOURCE: toshiba 1tb external hard drive won't connect
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer.
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
7. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
8. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
SPECIAL NOTES
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Hope this gives you the information you need
SOURCE: My computer is not recognizing my LaCie external hardrive
First cehck whether your computer is able to recoznize other USB storage devices or not. If you see that it is not recoznizing other USB storage devices. Then you need go to your Boot Up screen, the screen that opens when you restart your PC.
Then go to the USB section and enable USB drive.
If this also does not resolve your problem, then try installing USB drivers on your PC, You can install them from the website : http://www.softwarepatch.com/tips/usb2-driver.html
I hope this resolves your problem.
