GE FUF14SVRWW Upright Freezer Logo
A
Anonymous Posted on Mar 13, 2014
Temp setting is L - GE FUF14SVRWW Upright Freezer
Need lowest actual temps achievable by various upright freezers.
no rule of thumb
maybe if you got a different thermostat that has a lower setting than standard
however as upright freezers are very bad freezers compared to chest type freezers the lowest reading will be around the -35 degrees C
Why very bad -- every time you open the door you dump 20 degrees out onto the floor and the temp difference is more pronounced than opening the lid of a chest unit which keeps all of the cold in the unit
remember the colder the setting the more the compressor is working
Jul 08, 2018 • Freezers
What does the temp display on the freezer tell me?
unless this is a dedicated freezer only and not a side by side or over/under , there's no way it's going to get down too 0 degrees inside a warm home , nope not gonna happen
also its not good for you to set this there as compressor wont cycle properly there and entire freezer will ice up , then believe it or not it will get warmer not colder wastes a lot of power as well
Sep 10, 2015 • Freezers
Replacing true kegerator parts
no use a Ranco p# A12-700 make sure the capillary is in the coilto sense the temp and set it to 1.5 on the knob. any colder and it could get too cold . you may be able to set it at 2 but be careful. it is a constant cut in at 37 degrees coil temp. the box temp will drop to usually to 28 or 29 at cut out.
9helpful
Settings
The freezer should be set at 4 or 5 to start. If that is not cold enough then move the temp knob to 6 or 7 to get it colder. the higher the # the colder it will get. Onse you set the new temp it will take around 4 hrs to get to the new setting.
Good Luck and please rate 4 thumbs up for the free answer.
How do I test the temperature control module for a kenmore freezer model 253.9284013
You need a multi-meter to do this. The temp.control is just a switch that closes on temperature rise and opens on temperaure fall (or when it reaches the desired temperature). Using a meter set on ohms coneect to the 2 prong ends of the temp. control. Set the temp. control on off. You should not have any ohms because hte temp. control is open (no continunity) now set the temp control to 2 or 3 and it should close (the meter will read ohms or continunity)
if it does then the t'stat works. The only other exception is the temp. control will sometimes (this is rare) not properly sense temp. for example, it fails to sense zero degrees and it will either stay on too long to shut off too soon. I only seen this happen like twice in 20 years. but more or less this is how you do it!!!
hope this was helpful
1helpful
Frigidaire 25' chest freezer alarm goes off eventhough it is very cold
The temp sensor for the over temp alarm is probably maifunctioning if you are sure that the temp isnt rising
Dec 27, 2007 • Freezers
Top GE Freezers Experts
Arnie Burke
Arnie Burke
Are you a GE Freezer Expert? Answer questions, earn points and help others
