LE error is a locked rotor you need to have your hall sensor on the stator or better yet just have the whole stator replaced which comes with the sensor on it (P.S. the stator is part of the motor and has a 5 year warranty)
Stator is not covered by warranty if the problems was sensor.
stator doesn't go bad unless someone damaged it.
Washer is full of very wet laundry and stopped spinning half way through cycle. LE code
popped up and machine went idle. Turned power off, removed half of the laundry and started up again. This time it finished cycle. However, next time it failed again and now the LE code is constant.No apparent leak. Manual solution not encouraging - instructs to turn off power, turn off water and call for service. Oh no.
