What does an E3 error code mean on a Delonghi DE500pc dehumidifier
Condensation sensor was tripped...needs to be dried/cleaned/repaired (on lint screen side remove plastic panel. The sensor is clipped to radiator fins.
Be Safe or don't do it....
On the side with the lint screen, remove the five screws holding the top
panel in place. The sensor that needs to be checked in mounted on the
radiator fins. Remove the sensor and 4 pin connector. With a pin,
remove the loose fitting housing the "sensor"...a circuit board that
"shorts" with condensation...check corrosion and look for component
damage on the oft chance the circuit board was damaged by some
inappropriate poking or mechanical failure. Reassemble and replace
sensor...
For a short life span...or out of warranty and only at your risk (IF
have significant other or kids or pets or human DNA... don't do this...)
.. guide wire through screen notch and attach to outer screen. Build
fortress around exposed sensor and talk to insurance agent for a special
rider...seriously be careful.
Did you? Clean screen and GENTLY clean fins of lint, etc....(vacuum's brush head should do the trick...)
Taking all appropriate safety precautions.
Here's the 100,000 (yen) tip....with humidifier unplugged, hold down the
power button (green button in lower center) and plug in the appliance.
Watch the LCD screen as it conducts a self test...and wha...lah!.
