20 Most Recent
De'Longhi Dd30p 30 Litre Portable Dehumidifier With Pump System Questions & Answers
Where can I get replacement water bucket for Keystone KSTAD70A Dehumidifier?
Contact Keystone directly to inquire about replacement parts. They may have the exact bucket you need.
Appliance Parts Retailers: Websites like Appliance Factory Parts often carry replacement parts for dehumidifiers, including water buckets.
Online Marketplaces: Check platforms like Amazon, eBay, or other online retailers for compatible replacement buckets.
I bought a model #WDH70EAPW dehumidifier and it runs but the bucket does not fill.
Is the unit set to continuous drainage mode. That bypasses the bucket. If the humity level is already low, the dehumidifier might not collect much water. Is the air filer or drainage system clogged? If the refrigerant level is low, the dehumidifier might not be able to extract moisture. Finally, if the water level sensor or float assembly is malfunctioning, the bucket might not fill. Inspect for damage.
r
My 50 pint CA compressor om on but not the fan. Fan turn fine.
Replacing the fan's capacitor might resolve the issue. But replacing the fan's motor might be necessary. Other potential possibilities are the thermostat or control board. Inspect them for faults. Also, a loose or damage wiring might be a source of trouble.
Comfee Model M70DK has drain hose attached and now drains but also fill bucket. I want it to keep using drain hose and not the bucket
Here are some steps to ensure it uses the drain hose exclusively and stops filling the bucket:
Verify Hose Connection: Ensure the drain hose is securely attached to the outlet and positioned correctly. A loose or improperly connected hose can cause water to divert into the bucket.
Check Settings: Some dehumidifiers have a setting to prioritize continuous drainage through the hose. Double-check the user manual to ensure this mode is activated.
Inspect the Hose for Blockages: Even a partial blockage in the hose can cause water to back up into the bucket. Clean the hose thoroughly to ensure smooth drainage.
Elevate the Unit: If the hose is draining upwards, make sure the dehumidifier is elevated to assist gravity and the pump mechanism.
Disable Bucket Drainage: Some models allow you to disable bucket drainage entirely when using a hose. Refer to the user manual for instructions on how to do this.
M70DK Midea Replacement Parts - Midea Comfee's customer support might be necessary to contact.
Hiscense dehumidifier DH7019K1G- E9 error
Some additional steps to consider:
Inspect the Humidity Sensor: The E9 error often points to a faulty humidity sensor. Dust buildup or wear and tear can cause it to malfunction. Cleaning or replacing the sensor might resolve the issue.
Check Wiring Connections: Loose or damaged wiring between the control board and the sensor can trigger the error. Inspect all connections for signs of wear or disconnection.
Test the Control Board: Even though you've replaced the circuit board, ensure it's functioning correctly and communicating with the sensor. A professional technician might be needed for this step.
Continuous Drainage Issue: Since the bucket is filling up despite using a hose, double-check the drainage setup. Ensure the hose is properly connected and positioned to allow water to flow freely.
Reset the Unit: Perform a hard reset by unplugging the unit for at least 5 minutes before restarting it. This can sometimes clear error codes.
You might have to resort to contacting the manufacturer for assistance if the above steps don't help.
Airforce WDH-820EAH Dehumidifier. What does the code LO mean on airforce dehumidifier WHD-820EAH?
Question edited for clarity, and CAPS. It is a 'WDH' not WHD.
Question moved from Misc.
It means you don't need to be running it.
What Does "Lo" Mean?
For the WDH Models, if the display screen shows "Lo" (or the right display screen is showing "Lo" in WDH series models), then there is too little moisture in the air for the unit to remove any more moisture from the air. This means the ambient relative humidity (%RH) is below 30%, which is the minimum setting.
How to use polar wind dehumidifier
Using the Polar Wind Dehumidifier PN: MDUDP-22AEN1-BA7 involves a straightforward process.
Here's a step-by-step guide to help you get started:
Setup and Initial Use
- Placement:
- Choose a location where the dehumidifier is needed, preferably near a power outlet and away from obstacles that could block airflow.
- Ensure there is at least 6-12 inches of space around the unit for optimal air circulation.
- Power Connection:
- Plug the dehumidifier into a standard electrical outlet. Make sure the outlet is properly grounded.
- Check that the power cord is not damaged.
Operating the Dehumidifier
- Turning On the Unit:
- Locate the power button on the control panel of the dehumidifier.
- Press the power button to turn on the unit. The display panel should light up, indicating that it's operational.
- Setting the Desired Humidity Level:
- Use the humidity control buttons (usually marked as '+' and '-') to set your desired humidity level. The typical range is between 30% to 80% relative humidity (RH).
- The dehumidifier will work to maintain the set humidity level by automatically turning on and off as needed.
- Selecting Operating Modes:
- Some models may have different operating modes such as Normal, Continuous, or Turbo. Refer to the user manual for your specific model to understand the available modes.
- Use the mode button to select the desired operating mode based on your needs.
What does E9 error code mean on a Hisense dehumidifier?
My unit runs for a half hour and then theme dreaded E9 comes up. Then the fan runs but no buzzing from the condenser. Sounds like everyone who buys this brand has this problem !! I will try the manic press and hold the start button and hope it works.
