Zanussi ZWF1440 Front Load Washer Logo
Posted on Jun 22, 2009
Affinity washer - error code E90 Panel replaced but washer will not reset. Beeps 9 times and code E90. Help!
5 Related Answers
Anonymous
  • Posted on Nov 21, 2006
SOURCE: E90 Error Code
an E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
A
Anonymous
  • Posted on Sep 09, 2007
SOURCE: AFFINITY ERROR CODE
door not close
A
Anonymous
  • Posted on May 09, 2008
SOURCE: affinity washer not wanting to spin!
My Affinity washer quit spinning during the rinse cycle 14 months after we purchased the machine. We checked to make sure ithe drain was clear, and we tried changing the size of the loads. Nothing we tried worked. I was not getting any error codes on the control panel. We called a technician out to our house to see if it could be fixed. He diagnosed the problem as the control panel. We called Frigidaire to see if they would help us out with the cost of the repair since the machine was only 14 months old, even though our one year warranty had expired. They stated that they would not cover the replacement of the control panel. After the technician replaced the control panel and tried the machine, it still did not work. He called the Frigidaire tech support to find out why, and they told him that he needed to replace the door latch system, not the control panel. After he replaced the door latch the machine worked fine. When researching this problem online, I discovered that Frigidaire has had several problems with the door latch system on their front loading washing machines. They previously had a class action lawsuit due to this problem. When I found this out, I called Frigidaire to see if they would pay the repair bill we had incurred, even though our warranty had expired 2 months ago. After they contacted the technician that worked on our machine, Frigidaire decided that they would pay the cost of the replacement door latch and the labor fee. We had to pay for the cost of the initial service call. If you are having this problem, I would suggest that you contact Frigidaire. They will require that you have a diagnosis made by a certified technician. According to our technician, the flow chart for the Frigidaire front loading machines is inaccurate, so if they make an initital diagnosis of a faulty control panel you may want to have them contact Frigidaire tech support to double check the diagnosis. Frigidaire may help cover the cost of repair if your machine has a problem with the door latch.
IFIXALL
Archie Ferrarini
  • 869 Answers
  • Posted on May 22, 2008
SOURCE: error code E90
Remove the front panel and on the right side at the bottom youll find the main Circuit board.There is a connector on the harness that needs to be making a tighter contact.Make sure that all the wires that are in  contact with the circuit board are firmly touching.Sometimes using a pair if pointed tweezers and a sewing needle will be all you need to fix this .There is hope so dont go out and replace any parts just yet. .
Anonymous
  • Posted on Aug 27, 2008
SOURCE: Electrolux 1087 E90
I found out the hard way that it's because the drain is blocked. Check the filter and even get a torch to look to make sure there is no coin or piece of wire jamming the pump.
Top Zanussi Washing Machines Experts
gerbee gomez
Sudeep Chatterjee
Sudeep Chatterjee
Kolbrun...
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
