Coffee Makers & Espresso Machines Logo
Ed Camacho Posted on Mar 15, 2018
My NEWCO AKAP PO is not brewing and no hot water is coming out only cold.
5 Related Answers
mgprice
Mike Price
  • 744 Answers
  • Posted on Aug 15, 2009
SOURCE: How do I set the brew ratio?
Hello, I have worked on many bunn and other make ice tea makers but am not too familiar with this one, but as is common to all there should be 2 timers, one for the hot one for the cold. They are normally located under the top panel or inside the front panel. for 3 gallons you should be brewing 64oz of hot water through the 1oz tea bags (3-4) depending on taste as a rule of thumb. Please feel free to comment again if you have any other questions. Good Luck! Mike
Testimonial: "Great! Thanks for the advice. That's what I needed to know. Can't believe you answered so quickly. Wow!!"
Anonymous
  • 3 Answers
  • Posted on Jul 11, 2010
SOURCE: Water doesn't come down when brewing
I had the same problem, and it turned out it was the top needle that was clogged. I used a safety pin to clean out the needle and it worked again . . . I descaled immediately, just in case it needed that too. I am back to coffee goodness!
john h
  • 29497 Answers
  • Posted on Jul 26, 2010
SOURCE: no hot water
need to adjust anti-scold when unit shipped is set for cold if u have install paperwork that has info on how to adjust if not remove handle and on valve stem will see blue and red plastic clips slid them forward and adjust till hot water is adjusted to liking
EsWorld
Ernest R
  • 1618 Answers
  • Posted on Jun 14, 2011
SOURCE: My newco direct water fed
You are right on it is the solenoid, there might be something keeping it from closing properly.
Anonymous
  • 43501 Answers
  • Posted on Aug 07, 2011
SOURCE: won"t brew the coffe right and hot water coming
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Top Newco Coffee Makers & Espresso Machines Experts
ADMIN Andrew
ADMIN Andrew
john h
Kolbrun...
Are you a Newco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
