Apple iPhone 3G Logo
Anonymous Posted on Jan 18, 2010
How do i restore iphone
Restore
Anonymous
Level 2:
  • Expert 69 Answers
  • Posted on Jan 19, 2010
Anonymous
Expert
Level 2:
Answers
69
Questions
Helped
23881
Points
166
If you mean reset to factory, go to settings, then general, scroll down to reset at bottom. hope this helps.
  • Anonymous Jan 21, 2010
    Whenever you restore your iPhone or iPod touch, Apple highly recommends that you perform a sync prior to restoring in order to back up any changes since your last sync. If you have movie rentals on the device, see iTunes Store movie rental usage rights in the United States before restoring... sorry, i read restore, and thought reset lets try this again. hope this helps.
    Use the following steps to restore your iPhone or iPod touch:
        Make sure you have the latest version of iTunes installed and running before attempting to update.
        Connect your iPhone or iPod touch to your computer.
        Select your iPhone or iPod touch when it appears in iTunes under Devices.
        Select the Summary tab.
        Select the Restore option.
        When prompted to back up your iPhone or iPod touch's settings before restoring, select the Back Up option (as seen in the image below). If have just backed up the device, it is not necessary to create another.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jul 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
2958
Points
5
Reset to factory settings iphone 6
You can resort to iTunes to restore iPhone to factory settings. Just follow below steps to do that.
Restoring iPhone to Factory Settings with iTunes
iTunes enables users to back up data to iTunes and restore iPhone to factory settings. Before you start restoring iPhone to factory settings, please note that you need to install the latest version of iTunes on your PC or MAC. Then go to Settings > iCloud to turn off Find My iPhone. Now, the detailed restoring steps are as follows.
1. Plug iPhone into the computer with the USB cable. The iTunes on your computer will automatically launch. If not, double-click the icon to start it.
2. Click the name of your iPhone at the upper right corner of iTunes, and then the information of your iPhone will be shown. Click the "Restore iPhone" button in the window to start.
3. iTunes will ask whether you want to back up iPhone before restoring. You'd better choose "Yes" for the reset will erase the contents in your iPhone. Then iTunes will start restoring your iPhone to factory settings.
3. Click Restore again to confirm. Then iTunes erases your iPhone and installs the latest iOS or iPod software. After you restore your iPhone to factory settings, it will restart. Now you can set it up as new.
For more methods, check: How Do I Restore My iPhone to Factory Settings
I have a iphone 7 s plus and im locked out of it and i try to restore and download it to my laptop but when its close to being done it crashes i need help.
If you tend to restore iPhone to factory settings, there are two methods for you.
If this solution won't work, follow this post. How Do I Restore My iPhone to Factory Settings
How to factory reset iphone 4 withouw icloud password?
It's quite easy. You can resort to iTunes to reach this aim. Just follow below steps.
iTunes enables you to restore iPhone 6 Plus to factory settings. Before you start restoring iPhone to factory settings, please note that you need to install the latest version of iTunes on your PC or MAC. Then go to Settings > iCloud to turn off Find My iPhone. Now, you can factory reset your iPhone 6 Plus with iTunes as follows.
1. Plug iPhone 6 Plus into the computer with the USB cable. The iTunes on your computer will automatically launch. If not, double-click the icon to start it.
2. Click the name of your iPhone 6 Plus at the upper right corner of iTunes, and then the information of your iPhone 6 Plus will be shown. Click the "Restore iPhone" button in the window to start.
3. iTunes will ask whether you want to back up iPhone 6 Plus before restoring. You'd better choose "Yes" for the reset will erase the contents in your iPhone 6 Plus. Then iTunes will start restoring your iPhone 6 Plus to factory settings.
3. Click Restore again to confirm. Then iTunes erases your iPhone 6 Plus and installs the latest iOS software. After you restore your iPhone 6 Plus to factory settings, it will restart. Now you can set it up as new.
For more methods, check: How to Restore iPhone 6 Plus to Factory Settings
Restore iphone contacts
If you have synced your iPhone XS Max to iCloud, it would be easier for you to retrieve deleted contacts from iCloud for iPhone XS Max and other iPhone models. The below steps would show you how to restore contacts you have deleted from iPhone XS Max from iCloud for your iPhone XS Max and other iPhone models.
1.On your computer, open icloud.com and log in with your Apple ID account.
2.Go to Settings tab on iCloud.com, then click "Restore Contacts" (in the Advanced section).
3.Then, you will see available versions listed by the date and time they were archived previously.
4.To the right of the version you want to restore, click Restore option.
5.Wait until iCloud finishes restoring your contacts before you change them. While it's restoring them, any changes you make aren't saved.
The restored contacts and contact groups will appear on all your devices set up for iCloud Contacts. If you haven't set up your iPhone XS Max for iCloud, on your iPhone XS Max, go to Settings > [your name] > iCloud, swipe Contacts option to green on the "iCloud" window, and then click "Merge" button. You could then view all restored contacts on your iPhone XS Max.
Actually, with iCloud, you can restore your contacts, calendars and reminders, or Safari bookmarks and reading list from an earlier version that was automatically archived in iCloud. However, restoring contacts for iPhone XS Max and other iPhone models requires you to have archived contacts to iCloud.com previously. Otherwise you won't be able to retrieve contacts from iCloud.com.
For more methods, check: How to Recover Contacts from iPhone XS Max/XS/X
3answers
How do I restore lost photos on my iphone 5
Download PhoneRescue apk for iOS and connect your iPhone to computer with USB cable > Choose Recover from iOS Device > Click the arrow button. It will let you select the type of data you want to recover, so just tick Photos and click on OK to scan your iPhone.
Feb 26, 2018 • Cell Phones
1helpful
Forgot passcode
If you have forgotten the passcode on your iPhone, you will have to restore the device.
To restore your iPhone -- which deletes all of your data (songs, photos, videos, apps, and so on) on the iPhone use the following directions. Be absolutely sure that you have backed up the content on your iPhone before restoring it.
Apple's official instructions to restore an iPhone are:
1. Connect iPhone to your computer.
2. In iTunes, select iPhone in the Devices list, then click Summary at the top of the screen.
3. Click "Check for Update." iTunes tells you if there's a newer version of the iPhone software available.
4. Click Restore. Follow the onscreen instructions to complete the restore process. When restoring, it is recommended that you back up iPhone when prompted. When the iPhone software has been restored, you can either set it up as a new iPhone, or restore your music, videos, app data, and other content from a backup.
Please also note that Apple representatives can't unlock an iPhone for you without restoring the iPhone, which will erase everything on it.
How to resert iphone
You can resort to iTunes to reset your iPhone with ease. Just follow below detailed steps.
restore-iphone-rcarq2zhug2hmvq3p5tn22ku-4-0.jpg For more details, check: How to Restore iPhone 6 Plus to Factory Settings
2helpful
My 3g iphone is locked disable and i dont have any passcode that i remember i can not go to itoones neither how can i unlocked
  • Rank: Apprentice
  • Rating: 100%, 1 Votes
Some of the advice from the reply from Joed911 is correct. I used to work tech support for Apple Care on the iPhone, and I can tell you that there is no link in iTunes that say's "Unlock your iPhone" THESE ARE YOUR OPTIONS .............. 1) Your daughter can remember the password she set. 2) You will need to restore his iPhone using iTunes. *** Assuming # 1 is not an option I have instructions on how to restore his iPhone. Restoration of iPhone to original factory defaults will fix your problem, with the downside that all data and information stored on your phone will be lost. Normally iTunes will make a backup automatically when you connect and sync the iPhone with the program, however, it?s still a good recommendation to copy out and backup everything that you may need on the phone before proceed to restore the iPhone. To manually back up his iphone: ~Connect to itunes , on the left side of the itunes page you will see the iphone icon. ~ Right click the iphone icon ( under devices) and choose back-up from the drop down box. To restore iPhone and reset the phone to default factory settings, follow these steps: ***Easiest way to restore his iPhone: (this will work if his iphone is recognized in iTunes under devices) ~ Just left click on the iPhone icon under devices in itunes , ~ under the summary pane you will the option to restore his iphone. ~ click "RESTORE IPHONE" ~ wait for the process to finish restoration . ***** If his iPhone is not recognized in itunes under devices you will not see the iPhone icon. In this case you will need to restore with this method. 1. Turn off iPhone ? Hold down the Sleep/Wake button for a few seconds until the red slider appears, then slide the red slider. Ignore this step if your iPhone is already off. 2. Press and hold down the Home button for about 10 seconds until a yellow triangle with a text which says Please Connect to iTunes appears. iPhone Recovery Mode 3. Plug the iPhone into Mac or Windows PC. Release the button if you haven?t. 4. Run and open iTunes if it?s not already opened yet. 5. iTunes will prompt a message that says iTunes has detected an iPhone in recovery mode. Click OK. 6. You will be taken to the iPhone pane. Then, click on Restore. 7. Wait for the full restoration process to complete, and the iPhone will be back to the original settings. AFTER RESTORING THE IPHONE YOU CAN >>>RIGHT CLICK IPHONE AGAIN UNDER DEVICES AND CHOOSE RESTORE FROM BACK-UP TO REPLACE SOME OF HIS INFO PREVIOUSLY ON THE IPHONE. Hope this was helpful , and Good Luck !! Teresa
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
5helpful
2answers
My daughter set a password for son's iphone 3G and she cannot remember the password, can someone advice me how to unlock the phone
Plug it into iTunes with it at the unlock screen. Somewhere it should say "Unlock your iPhone" or something like that in iTunes. Click it. Otherwise do a restore by going to the screen where it shows how much memory you have used up in iTunes and click restore.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Sudeep Chatterjee
Sudeep Chatterjee
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
