Posted on Feb 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When you put the machine on this is the error you see SC320
Bernard D'Souza
Level 2:
  • Expert 165 Answers
  • Posted on Mar 12, 2010
Bernard D'Souza
Expert
Level 2:
Answers
165
Questions
0
Helped
105322
Points
254
Polygonal mirror motor error.
You will have to replace the Polygonal mirror motor.
Error sc320 how to reset this problem please explain in detail. thanks.
SC320 IS A LASER PROBLEM .
KINDLY AND CEREFULLY REMOVE THE LASER UNIT AND WASH WITH DETERGENT VERY THOUROUGHLY AND DRY UNDER THE SUN FOR ABOUT THREE HOURS AND REPLACE IT BACK TO ITS POSITION .
IF U POWER THE MACHINE AND THE SAME PROBLEM OCCURS, CHANGE THE LASER COPLETELY.
GOODLUCK.
1helpful
Lanier 5635 error code displaying a SC320
sc320 on the Lanier 5635 is a laser unit error code. Often if you power cycle the machine (turn it off with the orange power switch on the left side of the copier, wait a few seconds, then turn it back on) the code will clear and the copier will resume normal operation. If the error code comes back or doesn't clear, you'll probably need to replace either the entire laser assembly or the polygon mirror motor inside the laser unit. These are best done by a professional -- contact your local Lanier service company if the problem persists.
1helpful
When my ricoh afico 1018 printor is on error corde desplay sc320?
SC320 is a polygon mirror motor error. It could be caused by a poor connection or a faulty circuit board, but the most likely culprit is the polygon mirror motor itself. Replacing this motor (part #G0291961) is the most likely solution.
Hope that helps!
2answers
Error code 320 on startup
SC320, THE ENGINE POLIGONAL OF THE UNITY LASER DOES not TURN PROPERLY BY DAMAGE, HAVE TO CHANGE IT BY ONE NEW.
1helpful
2answers
I have problem with Ricoh Aficio 1113, error code sc320
I am assuming you really meant an Aficio 1013 - SC320 indicates a polygonal mirror motor failure. This motor drives the mirror that distributes the laser to the drum. Could be a defective motor, poor connection between the motor and the BICU - one of the motherboards, damaged cable or defective BICU.
This will require a service call. Probably looking at an hour to diagnose the exact problem and an hour or two to repair plus parts. Could be as simple as a loose connector --- doubtful, but you never know.
2helpful
Error SC320
The laser motor is cooked
12helpful
2answers
Error SC320 Ricoh Copier
Change the polygonal motor of the laser.
1helpful
2answers
Desperate!!! Ricoh AP3800C error Need to print for christmas!!!
Fuser is not reaching operating tempurature. turn off the unit. Take the fuser out and reseat it. Power it back up. Ricoh Printers Error Codes Normally there are 3 levels of service call conditions in Ricoh printers.
Level A is the highest level. Machine can not be used until code is reset. The printer cannot be operated at all. Here is a list of common error codes.
Level B: The SC might be reset by turning the main switch off and on in some conditions.
Level C: The printer can be operated as usual except for the unit related to the service call.
SC302: High voltage power supply error
SC306: Charge roller home position error
SC320: Polygon mirror motor error
SC500: Main motor error
SC542: Fusing temperature warm-up error
SC543: Fusing overheat error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
1helpful
Ricoh 1022 - Error SC320
USE A BIG PHILIP SCREW AND REMOVE THE 2 PCS SCREW IN LEFT SIDE AND REMOVE THE COVER WHERE THE PAPER IS EXIT. YOU SEE A BLACK BOX INSIDE, AND USE A SMALL PHILIP SCREW TO REMOVE THE 4 PCS SCREW LOCATED IN HOLE. THEN LIFT UP THE BLACK BOX AND OPEN IT. BE CAREFULL
2helpful
5answers
Code SC320
i'd exprience the same problem once. what i did was to change polygon size laser. its working perfectly now
Top Ricoh Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
