Kenmore HE2 Plus Front Load Washer Logo
Posted on Apr 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a F01 code - Kenmore HE2 Plus Front Load Washer
Anonymous
Level 3:
President:
  • Master 1,382 Answers
  • Posted on Apr 13, 2010
Anonymous
Master
Level 3:
President:
Answers
1382
Questions
0
Helped
560808
Points
5097
The F01 fault code is indicating an EEPROM error or a PUMP DRIVER error. A communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred.
Possible causes of an EEPROM error:
A power glitch may have caused this error. Unplug the power cord for 3 minutes then reconnect power.
Possible causes of PUMP DRIVER error:
The pump driver fails to activate. Replace the the CCU board.
Most likely the CCU board will need to be replaced.
  • Anonymous Oct 14, 2011
    Did the CCU replacement work for this? I have the same error.
My MAYTAG BRAVOS will not dry clothes. Why does my MAYTAG BRAVOS show F01 code?
not good :>(
F01 means that the main relay control board inside your control panel has failed and your control board would need to be replaced to fix the issue.
Apr. 18, 2014
Maytag Bravos Dryer has F01 diagnostic code flashing and ...
1helpful
Why is my Maytag Epicz model #MGDZ600TW2 not starting amd giving me an error code F01. What does it mean?
F01 is a control unit failure does this come up when you push the start button or did you go into diagnostic to get this code I have seen it come up as a false code check the start button does it spring back like all the other buttons if so replace control if not the button is broke
MAYTAG 3000 F01 CODE
It's probably a weak or failed component on the board. It's a common issue on those machines and the Whirlpool Duets. It's usually burned at the motor relay or heater relay.
F01 error code flashes when there is a primary control failure.
The only thing which will solve an F01 error code is a new machine control board. These is a catastrophic control board failure. Nothing can correct it. The part number you require is W10205977.
Error code f01
all I can say to that is if you arrange the bath rugs in a balanced way so they are equally distributed then the problem should go away eric
Wont start, error code f01
The F01 error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU occurred. This type of failure generally requires replacing the Central Control Unit (CCU). You could try disconnecting the power cord for a couple of minutes and then reconnect the power cord. If it continues to flash "F01" I recommend calling a service technician to remove and replace the CCU.
Jan 16, 2011 • Dryers
2helpful
Hotpoint WMD washing machineFault Code F01 machine will not start
Fault code F01 indicates a problem with the motor triac.
Check all connections to and from the motor, the control module, and the motor plug
vince
Pieter Vleeshouwers
Pieter Vleeshouwers
