Dryers Logo
Posted on Jan 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wont start, error code f01 - Dryers
Richard Roth
Level 3:
Top Expert:
  • Dryers Master 9,472 Answers
  • Posted on Jan 16, 2011
Richard Roth
Dryers Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2675775
Points
28465
The F01 error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU occurred. This type of failure generally requires replacing the Central Control Unit (CCU). You could try disconnecting the power cord for a couple of minutes and then reconnect the power cord. If it continues to flash "F01" I recommend calling a service technician to remove and replace the CCU.
Maytag 5000 series steam dryer. It won't start. it keeps flashing F01. What does that mean?
Question edited for clarity.
Question moved from Misc Category.
F01 is a very straight forward error and it means that your dryer has detected a short in the main relay power control board mounted to the left side wall under the top panel of the dryer.
Oct 19, 2018
Our Maytag 5000 series dryer is showing an F01 error code.
JustAnswer https://www.justanswer.com > Appliance Repair
F01 - Error Code - Dryer
Maytag https://producthelp.maytag.com > ... > Starts with F
Dec 14, 2019 - Possible Solutions. Power unit down by turning off the circuit breaker(s) for one (1) minute. Power unit up by turning on the circuit .
1helpful
Why is my Maytag Epicz model #MGDZ600TW2 not starting amd giving me an error code F01. What does it mean?
F01 is a control unit failure does this come up when you push the start button or did you go into diagnostic to get this code I have seen it come up as a false code check the start button does it spring back like all the other buttons if so replace control if not the button is broke
110.4753 error code f01
I found this on the WEB-In reference to your Kenmore HE washer, model number 110.4753:
F-01 Error code
EEPROM ERROR
PUMP DRIVE ERROR
, or a
MAIN RELAY ERROR
EEPROM ERROR
: A communication error between the
(CCU) and the
EEPROM
onboard the
CCU
occurred.
PUMP DRIVE ERROR
: The pump driver fails to operate
MAIN RELAY ERROR
: One of the main relays is not working properly
MAYTAG 3000 F01 CODE
It's probably a weak or failed component on the board. It's a common issue on those machines and the Whirlpool Duets. It's usually burned at the motor relay or heater relay.
F01 error code flashes when there is a primary control failure.
The only thing which will solve an F01 error code is a new machine control board. These is a catastrophic control board failure. Nothing can correct it. The part number you require is W10205977.
Washer won't start. Error code f01 shows.
Hi F1 means your CCU is bad and needs to be replaced sorry :( If you have any other questions please feel free to comment again. Mike e63dqt.jpg
4helpful
F-01 error hotpoint WMD960P
Error code F01 is indicating ashort circuit motor triac.
Check connections on motor the motor plug and then control module.
Please rate my solution.
Thanks.
7helpful
HOW TO FIX A F01 ERROR ON MY DUET HLT WIRLPOOL WASHER
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Top Dryers Experts
AskDyson
AskDyson
ADMIN Andrew
ADMIN Andrew
