Posted on May 25, 2010
Error P25 , Konica 1312 - Konica Minolta Office Equipment & Supplies
Anonymous
Level 1:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Contributor 1 Answer
  • Posted on Jun 16, 2010
Anonymous
Contributor
Level 1:
Mentor:
Teacher:
Answers
Questions
0
Helped
1048
Points
Check for toner, if empty change with new one.
  • walter jansz
    walter jansz Feb 14, 2011
    p25 error code is common what you need to do is clean the idc sensors they sit under the transfer belt unit at the front were you take it out directly below there is a guide metal it slides left to right the idc sensors are under this shield when you manually slide it toward the back it exposes the idc sensors you cant see them but you get a soft clean cloth and clean in the hole areas of the cut out slots on the guide you slide
    Also ther is firmware to correct some of the p error codes
    doing the above will fix your issue you may have to change your transfer belt check life
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
