To program a known frequency into the BC340CRS:
- Power the scanner ON
- Press the E/PGM key to enter programming mode
- Enter the number of the channel that you wish to program
- Press HOLD
- Enter the frequency, including the decimal point (e.g., 156.225)
- Press E/PGM to enter the frequency into memory
Press the UP or DOWN arrow to advance to the next channel you wish to program
Press HOLD or SCAN to exit the programming mode.
More detailed programming instructions can be found in the factory operating manual which you can download and print, free of charge, here:
http://www.radiopics.com/1.%20Manuals/Bearcat/Bearcat%20BC340CRS%20%28Manual%29.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
SOURCE: frequency numbers for bell county
For a copmprehensive database of active frequencies in your area, visit:
SOURCE: Detailed instructions on how to program Uniden
Your best course is to follow the simple programming instructions in the factory manual which you can download and print, at no cost, here:
http://www.uniden.com/pdf/BC340CRSom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
Bill B.
SOURCE: i have a uniden bc340crs scanner how do i get
http://www.radioreference.com/ is the absolute best source there is.
Go there, and click "Database" in the top nav-bar. It will guide you through picking your state and county, or you can enter your ZIP code to pick your location. Once there, it will have tons of frequencies for anything that's publicly available in your area.
SOURCE: How do I program my
The best programming instructions are contained in the owner's manual which you can download and print, at no cost, here:
Bill B
SOURCE: uniden bc340crs scanner just static
An unfiltered power supply my give that problem or you need an external arial
going by those instructions every time i hit e/pgm at the end it reads" error "
i am having the same problom
same here
