Kenmore HE2 Plus Front Load Washer Logo
Posted on Dec 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Code D5, what is it? - Kenmore HE2 Plus Front Load Washer
Richard Roth
Level 3:
Top Expert:
  • Kenmore Master 9,472 Answers
  • Posted on Dec 11, 2010
Richard Roth
Kenmore Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2675775
Points
28465
A d5 error code usually means Sd. This error code is displayed when the control detects the basket has not seated on the hub or that the pressure switch has detected a Suds-lock condition. The washer will try to run a mini-clean out cycle using cold water and a 5 minute pause to clear the suds. If this cycle does not clear the display and complete the cycle the clothing may need to be rinsed by hand and then rewashed. The fault is caused by using the wrong detergent or excessive amounts of detergent.
Note: If the Hard Reset does not work, there may be an internal failure with the washer.
What does a flashing code d5 on a Blue Air Commercial Freezer mean?
Question moved from Land Phones category.
CL is telling you to close the door. The is nothing about D5. Contact them direct.
Page 13 here
https://www.qremshop.com/wp-content/uploads/2019/01/Owners-Manual-BSF.pdf
Jan 14, 2022 • Freezers
Samsung front load washer code d5
The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. the problem is related to faulty door locking assembly.There is a switch in back of door, if this fails it wont work. God-Bless!
2003 acura tl d5 blinking and jerking
D5 blinking is a trans code, problem. A scanner is needed for the OBD plug to get the code. Trans issues very common on this model.
21helpful
D5 error
Error code D5 OR DS is the same.Its mostly DS which looks like D5. The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly. But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem.
Hope helps.
21helpful
2answers
Not sure if this is the right wasing machine that matches ours or not but we are getting a d5 error and don't know what it means
The error code D5 OR DS is the same.Its mostly DS which looks like D5. The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle.The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly.But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem. This has to be checked to confirm the fault.Keep updated with any more queries.Thanks.
1helpful
WASHING MACHINE DOES NOT GO ON
Check your display panel again- there is no such error code for the LG WD-3245RHD. You can have: "dE", "tE", "FE", "PE", "CE", "LE", or "dHE" but there is no "D5" error code.
3helpful
4answers
Need latest telewest code
telepest-01-D2 EA 29 B7 B5 52 E9 AD.key.00-04 4D 6F 7D D5 C9 F7 9B c/wkey0.2A E0 72 B0 9E 07 9B 5D..key01..B5 8E A1 3E 6F D7 BD D2.
notsopurekeys-key0-31 6F CB 3F 2E 45 5A 04..key01.EA B7 BF B2 D5 AA 46 AB
irelandntlkey0-75 92 B1 CC 6F 23 20 F1..key01-F2 46 B1 59 04 61 77 71
irelandchoruskey0-51 0F 32 A7 D9 34 BE 3E.key01.8D A3 88 1B 4E 32 C5 8F..
all above as of 28/11/08..18.00pm
enjoy....for how long...god knows...but we need a new firmwarte fast...
4helpful
Error Code d5
It sound like a loose or a broken lid switch issue. The lid switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Good luck!
vince
Pieter Vleeshouwers
Pieter Vleeshouwers
