Konica Minolta bizhub C250 All-In-One Laser Printer Logo
A
Anonymous Posted on Jan 13, 2011
What is error code 35752 for konika minolta? - Konica Minolta bizhub C250 All-In-One Laser Printer
carpediemweb
Level 1:
  • Contributor 54 Answers
  • Posted on Jan 19, 2011
carpediemweb
Contributor
Level 1:
Answers
54
Questions
Helped
73406
Points
82
The code mut be 4 letters, not five. it will be C3572 or C3575 ... C3752 Abnormal High Temp. (Press) (fixing unit to be changed) - This is the error that seems to be the best explanation.
2answers
Proceed to continue using the machine konica minolta bizhub 165 when I get the message error M2
http://www.copytechnet.com/forums/konica-minolta/62595-konika-minolta-bizhub-163-error-code-m2.html
Code error 0060
Fusing drive motor failure check the fuse the hot section of the machine REPLACE the fuser first if not that then the fuser took the motor out worse case the fuser took the motor and the control board.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1helpful
Konika minolta bizhub 215 error code m2
You need to go into the service mode and then reset the supplies life counter.
1helpful
Konika minolta di1611 error xodes
You must be change the developer and the opc drum and drum cleaning blade.
9helpful
21helpful
3answers
How can i reset m2 bizhub 211
I Have a Konika Minolta bizhub 211. I had been trying this solution for repairing m2 call. but the code is appear till now. anyone help me. please give me solution step by step.
Thanks
2helpful
HOW DO I SOLVE ERROR CODE C3451 IN KONIKA MINOLTA BIZHUB C200
You will need to replace the thermostat and the best solution is to ask a technician to do that.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
