Sharp AR-5320 Black and White Copier Logo
Posted on Jan 19, 2011
HOW CAN I SOLVE THE PROBLEM OF SHARP AR-5320 THE DIGITAL APPER H THEN 2 THEN H THEN 2
Anonymous
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Jan 19, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
22
Questions
Helped
15418
Points
55
'H2' indicates a problem with the thermistor (temperature sensor) in the fuser unit.
You can try resetting the code using the following key sequence:
C, [Pause key], 0, [pause key] - You need to press these keys in sequence within 5 seconds.
The display will change. Enter 14 then press the copy button.
The machine will then reboot.
Hopefully the machine will now work. If the code comes back make sure that the fuser unit is properly inserted. Check that there is no jammed paper blocking the connector. Locate the Thermistor and check that it is not damaged (hard toner can build up on it causing damage).
Hope this helps.
Top Sharp Office Equipment & Supplies Experts
George Mclaughlin
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
