SOURCE: Error code ER FF
The error indicates the freezer fan is not functioning properly. The
fan supplies cold air to the refrigerator that is why it seems warmer.
The fan may be frozen, try unplugging it for a few hours to let it
thaw. Also check to see if something may have gotten into the vent
holes in the freezer that could be blocking the fan from turning.
SOURCE: error code er ff on my kenmore elite bottomfreezer model 795.7756
I fixed it. ER FF is "Error Freezer Fan." Once the evaporator fan stops turning for more than 115 seconds, this error message will be displayed. This fridge is poorly designed and is not designed with air gaps or enough air gaps to allow air behind the back panel of the freezer where the fans and condenser coils are located thus causing ice to build up around the fan and it's ability to spin. The evaporator fan helps cirulate the cold air generated by the condenser coils.
The fix is (1) defrost your refrigerator which means you'll loose all your food if you don't have another unit to keep the food in until it's done defrosting or (2) to dismantle the entire freezer by removing all the trays and railing so that you can pull the back panel far enough to get the front end of a hair dryer over the top lip of the panel to melt the ice. My unit had ice build at the top right and left corners behind the panel. I opted for the latter and didn't have to throw any food away.
This is going to be an annual chore if I want to keep this refrigerator. We should all ban together and call for a recall.
SOURCE: LG refrigerator lrsc26944tt error code ER FF
I'm no major appliance repairman. However, after reading several posts, I investigated the issue further since I received an ER FF on the front panel. I have a LFX25960SW refrigerator. I pulled the top and bottom baskets out, and was able to take the back panel out from inside. There was a solid block of ice built up around both fans and wires. I took a blow dryer and gradually melted the ice around the fans and wires. Then, as I was able, I pulled the remaining ice chunks off of the wires. I put the thing back together and it cleared the message. My wife says no more LG appliances for us. :)
DAS
SOURCE: The LG refrigerator ER FF fix
I had this same problem, with the thing freezing up, and this is how I solved it -- I took everything out of the fridge, I defrosted it for a few WEEKS (yes, weeks), cleaned the thing thoroughly, replaced the water filter, and fired it up again. So far, it's been two months, the thing is quiet as a grave, and running like a champ.
I think if you let ice form around the condenser fan, it will not go away easily. I tried the hair dryer trick, the "unplug it for a while" trick, but nothing worked. After a week or so I'd hear that grinding sound (which I think was the condenser fan and a huge chunk of ice doing their thing).
This refrigerator doesn't like to be opened a lot, and it doesn't like a door being left open, even a tiny bit, at all. The right door of the refrig can stay slightly open without the annoying beep happening, and the bottom freezer can also be slightly ajar and the beep won't go off. It's a trick to get everyone in the family to pay attention to this and make sure that the doors are all closed TIGHTLY, particularly the freezer door.
I called up the (not terribly helpful) LG people and they denied a systemic problem with the frig, and they also denied that cutting insulation was a good idea.
I am not sure what the truth is, but so far, so good with the lengthy defrost. Of course, if you don't have a spare frig, or you're not prepared to live out of a cooler for many days (I do think you need several days to get that massive block of ice melted) to try this fix, you may not be interested in it.
