20 Most Recent Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Questions & Answers
Water filter stuck on my Kenmore Fridge
I had the same problem. I coudn't get the knob to turn. I ended up taking the front grill off so I could get a better grip on the knob. Once I did that I still have to put a lot of pressure on the knob to turn it but that did the trick. When I got it turned a quarter turn then it was easy to pull the filter out. Hope this helps!
12/10/2021 9:12:54 PM • Kenmore 55612 /... • Answered on Dec 10, 2021
2answers
Side by side door
Depending upon your model it could either be a sagging door hinge (requires replacement) or the fridge my not be level. If you remove the toe-kick panel there will be a couple of bolts which are used for leveling ( they should be indicated as such or shown in your owners manual). Alternately there may be screw type legs which are used to level your fridge.
The seal should improve once the doors are properly aligned.
11/2/2021 12:33:51 PM • Kenmore 55612 /... • Answered on Nov 02, 2021
3answers
Light bulb stays on in Kenmore Elite fridge Model # 795.77559600
I had the same problem with a kenmore elite fridge and recieved the same response from Sears customer service!!! File a complaint with your local BBB. Sears contacted me within the day and sending out a tech at their expense only after the complaint was filed. Good luck. Elana
12/28/2020 8:27:27 PM • Kenmore 55612 /... • Answered on Dec 28, 2020
2answers
Replace icmaker on kenmore
The problem could also be the Emitter or receiver unit. This unit detects the level of ice in the ice bucket and when it gets full the ice blocks the optical path shutting down the making of ice till optical contact is made. See the attached jpeg for troubleshooting steps. optics boards - resized-undefined-undefined-0.jpeg
6/10/2020 7:26:24 PM • Kenmore 55612 /... • Answered on Jun 10, 2020
0answers
Kenmore elite 106.5770 ice auger motor is out.
This is probably one of the best videos I have ever found on replacing auger motors...at least how to access them in Kenmore units. I hope this helps you with your issue.
11/28/2017 4:14:24 PM • Kenmore 55612 /... • Answered on Nov 28, 2017
Model #253.54739304. My ice maker works fine but
Your fridge was made by Frigidaire / Electrolux corporation for Sears Kenmore. This is the parts manual for your model. http://b2b.frigidaire.com/support/ResultsPage.asp?strModel=253.54739304&User=&Search=Search ftp://ftp.electrolux-na.com/ProdInfo_PDF/Anderson/5995400073.pdf
10/26/2017 9:22:34 AM • Kenmore 55612 /... • Answered on Oct 26, 2017
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
1,480 questions posted
Top Kenmore Refrigerators Experts
vince
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
light bulb stays in kenmore elite fridge
  • Refrigerators
