Just go here, it has all th diagrams you need to fix the problem:
http://mye-life.blogspot.com/2010/12/how-to-fix-tz-tape-cartridge-for-label.html
It's a long-shot, but I actually bought a TZ tape where the tape had been mis-routed inside (manufacturing defect). Re-routing the tape fixed it...
thanks but how do you do that and i have just tried it again and on the "big" size set it is printing but just very very light you can see the horizontal lines better then the vertical
You have to take the tape case apart to fix a rerouting problem, but if you get any printing at all then the routing should be fine. The only other solution I can offer is to look at the mechanism that holds the tape to the print head. There could be some kind of tension spring that is broken, or another mechanical problem...
