Thanks for your suggestions - I'll try leveling it first. I also wiped down the gasket with warm soapy water. Thanks for your suggestions - I'll try leveling it first. I also wiped down the gasket with warm soapy water.
You can't post conmments that contain an email address.
Make sure the door gasket makes a tight seal. Often they need to be cleaned (409 is my favorite) or they get twisted. They also sometimes come away from the door in spots. Pay attention to the bottom seal which you usually don't notice in daily use.
Depending upon your model it could either be a sagging door hinge (requires replacement) or the fridge my not be level. If you remove the toe-kick panel there will be a couple of bolts which are used for leveling ( they should be indicated as such or shown in your owners manual). Alternately there may be screw type legs which are used to level your fridge.
The seal should improve once the doors are properly aligned.
