Computers & Internet Logo
Posted on May 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
An error code of 32002 came up, what do we do?
Anonymous
Level 3:
President:
  • Master 2,340 Answers
  • Posted on May 30, 2011
Anonymous
Master
Level 3:
President:
Answers
2340
Questions
0
Helped
727890
Points
6960
Error Code: 32002 Likely causes: Your Internet connection has slowed or was interrupted, or the servers could be busy. Reference help links:- 1. Wii Error Code 32002 link @ http://www.wiierrorcodes.com/wii-error-32002.php 2. Error Code: 32002 link @ http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=32002&system=Wii&locale=lang Hope it helps.
Hi, um.... well my wii isn't doing the internet wifi thing there is a error code: 32002
Hi there.
This error is caused by the Wii being unable to receive an update from Nintendo's servers due to a technical issue.
To solve this error :
Try changing the channel on your wireless router to channel 1 or channel 11 which can increase download speeds.
Thank you!
What is code 32002 mean?
Error code 32002 when trying to update
Try changing the channel on your wireless router to channel 1 or channel 11 which can increase download speeds. The error means your wii encountered a connection error whilst downloading the update from nintendo, this could be your internet connection, or too many people on nintendo servers
My wii will not update gives me eror 32002
If you get an error code of 32002 or 52030 on you Wii console, this indicates a problem with your Wii communicating with your wireless router. There are a couple things you can try/check to help fix this problem.
1 - Try using a different channel on your router and update your Wii to take to the router on that channel.
2 - If your router is using WEP (encryption), make sure your Wii is set to the same encryption.
3 - Make sure the MTU values on your router match those entered on your Wii.
Also note that if you make changes to your wireless router and you have a computer that uses that router too, you'll need to update your computer to match the new settings on your router.
1helpful
I am trying to update my wii so i can get netflix. i keep getting an error code of 32002. how can i fix this?
If you get an error code of 32002 on you Wii console, this indicates a problem with your Wii communicating with your wireless router.
There are a couple things you can try/check to help fix this problem:
1.Try using a different channel on your router and update your Wii to take to the router on that channel.
2.If your router is using WEP (encryption), make sure your Wii is set to the same encryption.
3.Make sure the MTU values on your router match those entered on your Wii.
How to fix error code: 3002
hi there,
I couldnt find any error code 3002, but there is an error code 32002! If this is the error you got, this is nothing to worry about. this was the result of a failed update from nintendo, the console was not able to receive it for whatever reason. This will correct itself the next time you are connected to the internet with your console or will keep trying until it does update. Hope this helps.
1helpful
2answers
Wii nintendo trying to upgrade it but keep keeping error code 32002, please help
Usually this is a high network traffic error or possibly a connection error your side with your wireless signal. One thing you could try is changing the wireless channel your router is on.
Hope this helps
Error code 32002 when trying to get updates to allow access to wii shop, how to resolve?
Error Code: 32002 The Nintendo Wi-Fi Connection servers could be experiencing a high amount of traffic. Please try your connection again later.
If you have waited several hours and are still unable to connect, there could be an issue with your connection. Please review the folliwing information:
  • Ensure you have entered the correct DNS into the Wii console's manual settings (link). You can verify this by following these steps:
    1. Click the "Start" button in the lower left-hand corner of your computer.
    2. Click "Run."
    3. Type "cmd" into the box and press Enter.
    4. Type "IPCONFIG/ALL" and press Enter.
    5. The Subnet Mask, Default Gateway, Primary DNS (first listed), and Secondary DNS (second listed) information will be displayed. Ensure the information you have entered into the Wii console's Manual Settings appear exactly as displayed.
    6. If you have more than one DNS server listed, try switching the first and second in the Wii's primary and secondary DNS server slots.
  • Try temporarily disabling your router's firewall. *
2answers
I con't update my wii error code 32002
"Wii error code 32002" The Nintendo Wi-Fi Connection servers could be experiencing a high amount of traffic. Please try your connection again later. If you have waited several hours and are still unable to connect, there could be an issue with your connection. Please review this information to correct the problem, click on the link below:
http://www.nintendo.com/consumer/systems/wii/en_na/errors/results.jsp?error_code=32002&system=Wii&locale=en_US&action2.x=27&action2.y=25
2helpful
2answers
What is error code 220602 on the wii
220602 means there is a problem with the internet settings.
when entering your setting use manual settings to set up. manually entering the DNS settings when the screen comes up.
(note: errror code 32002 means the same thing)
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
