SOURCE: Bizhub C250
Select separate scan in scan setting screen, select utilities, user settings, initial settings, current settings.
SOURCE: Konica Minolta Bizhub 250 Authentication issue
What you require can be achieved though the "public access" settings. This will allow you to control what can happen without requiring a log in.
SOURCE: konica minolta bizhub c250- error code c-0212
Something is going wrong with your LCT!
I am looking into it...
SOURCE: how do you reset the life of the transfer unit on the Bizhub C250
the fuser must be a fast blow 60mA, otherwise it will not work.
SOURCE: The printer has stopped functioning all together.
C3851: Abnormal Low Temp. (Heater)
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Testimonial: "This is exactly what I needed to do to fix this error. I got it fixed a long time ago but this is the correct answer!!!"
