American Audio Radius 1000 CD MP3 Player System Logo
Posted on Jul 27, 2011
I have a disc error display on my radius 1000, how do i fix that
1 Related Answer
Anonymous
  • 69 Answers
  • Posted on Dec 30, 2010
SOURCE: keep geting disc error on
your CD MP3 player's lense may have damaged.
thanks
My piano Yamaha psr 1000 has problem of button when I press breaking button it breaks, display style and play demo simultaneously
It seems like your Yamaha PSR 1000 has a malfunction where pressing one button triggers multiple functions simultaneously. This could be due to a faulty connection or internal component. Have you considered contacting a professional technician to diagnose and repair the issue? They should be able to assess the problem and provide a solution to fix the buttons and prevent simultaneous triggering of functions.
1helpful
I have a 2015 Gibson LPM with the zero fret nut. I have replaced the brass zero fret nut with the replacement that Gibson sent me. My problem is with the G string not intonating. Other strings r fine.
It's possible the fretboard radius and bridge radius doesn't match so that the zero fret isn't making enough contact. It may be possible to recut either the nut slot or the saddle to get it all to work. Find a good repairman, not a guitar cener guy, or if it was bought new, send it back to Gibson under warranty.
How do i open the lead?
I need much more information. Please reply here.
1helpful
How do i fix my cd mp3 lense?
Other than cleaning VERY CAREFULLY, there is no DIY on a damaged lense assembly, only replacement. Clean with 99% isoprophyl alcohol and a Q tip VERY gently and leav no cotton strands.
Top console is not working on Pro 1000 Dual Scratching CD Player
Check controller cable between base and remote. Look for bent pins. If appears ok, you may have an internal loose connection. Try and narrow down if loose section is on base or remote. You could have it resoldered if needed. digitalrepair@hotmail.com
2answers
How to fix Toshiba laptop with missing or corrupt file WINDOWSSYSTEM32CONFIGSYSTEM
There are many ways to attempt a fix with this error you could try firsta boot into safe mode then running msconfig
select the diagnostic startup then reboot in the normal way this might enable you to find your error.
If this fails click the LAUNCH SYSTEM RESTORE which maybe able to use one of your restore points created at an earlier time (usually before an app install) this may give you the fix you require.
Dec 14, 2009 • Music
3answers
My stanton c324 after i put a dics in it reads "no disc" what happend to it and how can i get it fixed?
Had same issue with mine, talking with retailer it seems to be a common problem. I am in New Zealand and have been waiting 2 months for parts to arrive. Something wrong with laser and servo. Good luck getting yours fixed.
Top American Audio Music Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an American Audio Music Expert? Answer questions, earn points and help others
