20 Most Recent Newco CBD-1.5 Dual Commercial Barista Coffee Brewer Questions & Answers
Need to brew coffee
You need to go on line to the manufactres web site and seek Support.
3/25/2014 9:13:54 PM • Newco CBD-1.5... • Answered on Mar 25, 2014
Newco AK3 Pour Coffee Maker
Ensure that you've chosen the appropriate carafe size option that corresponds to the quantity of water you included.
8/31/2023 12:06:00 PM • Newco Coffee... • Answered on Aug 31, 2023
Adjusting water flow Newco coffee machine
replacements parts for NKL3AF:front switches for upper front & rear not plates and for the brew start/ready green lampCan I download the users manual/guide too?thanksManuel Florez(787)609-4115bsat4ube4gblqiaaaaasuvork5cyii=
2/4/2015 5:52:14 PM • Newco Coffee... • Answered on Feb 04, 2015
0answers
2answers
Gaggia Classic coffee pump does not function properly
Use the bottom pic for help.
8/23/2026 10:49:24 PM • Coffee Makers &... • Answered Yesterday
2answers
Hi there I have an old brevetti gaggia with an H64
You most likely will have to contact the manufacturer.
8/21/2026 11:35:14 PM • Coffee Makers &... • Answered 3 days ago
My coffee mach0ine wont brew
If your coffee machine won't brew, check that it has water, coffee, and power, and make sure nothing is clogged. If the problem continues, clean and descale the machine, as mineral buildup is a common cause.
7/22/2026 3:25:35 PM • Coffee Makers &... • Answered on Jul 22, 2026
My Jura Impressa Z5 display says Powder Funnel, what does this mean? It won't clear
The Powder Funnel message on your Jura Impressa Z5 usually indicates that the machine's sensors detect an issue with the pre-ground coffee bypass chute. This often happens if the funnel lid is missing, the sensor is dirty, or the chute is physically blocked. Why it Won't Clear and How to Fix It Missing or Misaligned Lid: The funnel lid contains a magnet that tells the machine the chute is closed. If the lid is missing or not seated perfectly, the message will persist. Ensure the lid is present and clicks into place. Clogged Chute: Coffee grounds (especially if ground too fine or if oily beans were used) can build up and block the internal path. Use a torch to look down the chute; if you see a blockage, gently break it up with a spoon handle and vacuum out the residue. Stuck Microswitch/Sensor: Moisture or coffee dust can cause the sensor to stick. Try cleaning the area around the funnel door with a dry cloth or Isopropyl Alcohol to ensure the contact point is clear. Hard Reset: If the message is a "ghost" error after cleaning, unplug the machine for 10 minutes to allow the internal memory to reset. If these steps don't work, you may need a replacement lid or professional service if the internal sensor has failed. Detailed maintenance steps can be found in the Jura Impressa Z5 Manual. Is the funnel lid still attached to your machine, or has it recently come loose?
3/3/2026 8:05:43 AM • Coffee Makers &... • Answered on Mar 03, 2026
Aerolatte Milk Frother Chrome: How to eject the wand and replace with a new wand please?
The Aerolatte Chrome frother is a single, integrated handheld unit, and the whisking wand is not designed to be ejected or detached from the main body. The entire wand and whisk assembly are one sealed, stainless steel part that extends from the battery housing. For cleaning, you simply rinse the whisk end under the tap or place it in a cup of hot, soapy water and briefly turn it on to clean itself. A "transit rod" (a black plastic protective tube) may be in place when new, which can be removed by pulling it vertically off the whisk head, but this is a packaging item, not a functional part of the device once in use.
1/13/2026 3:15:53 AM • Coffee Makers &... • Answered on Jan 13, 2026
How do you descale a direct water plumbed Saeco 7P Plus machine?
You'll need to run a descaling cycle using the machine's internal system since the direct connection prevents soaking, and consulting a plumbing lead generation agency uk could also help if you need professional guidance on modifications.
12/22/2025 7:11:20 PM • Coffee Makers &... • Answered on Dec 22, 2025
Grinder run time less coffee weaker?
Clogged or partially blocked grinder chute is the most common cause. But the burrs might be worn.
12/22/2025 3:31:13 PM • Coffee Makers &... • Answered on Dec 22, 2025
My siemens Tk76k572 coffee maker isn't showing any display on the display panel.How can I solve this???
If your Siemens TK76K572 coffee maker's display is completely blank, start by checking the power supply and fuse, then try a reset by unplugging for 1-2 minutes. If the machine still doesn't show any display, the issue is usually a faulty control board or display module, which requires professional service or part replacement
12/8/2025 2:01:02 PM • Coffee Makers &... • Answered on Dec 08, 2025
HI, ECAM 25.462B what is alarm OG6LNY ?
That's an interesting question. The code "OG6LNY" doesn't appear to be a standard error or alarm code for a De'Longhi ECAM 25.462B coffee machine. De'Longhi error messages are typically displayed as icons on the screen (like a flashing water droplet or coffee bean symbol) or as a short, direct message like "General Alarm," "Insert Infuser," or "Descale." Could "OG6LNY" be a typo, or perhaps a serial number or a part number you're seeing somewhere on the machine? To help you troubleshoot, could you describe what the machine is doing? For example: * Are there any lights flashing on the control panel? * Is there a specific symbol or icon displayed on the screen? * Is the machine making any unusual noises? In the meantime, the most common alarm for this type of machine is the **"General Alarm,"** which is usually indicated by a red triangle with an exclamation mark (!). This can be caused by several issues: 1. **The infuser is not inserted correctly:** Try removing it, rinsing it with warm water, and re-inserting it until it clicks into place. 2. **The inside of the machine is dirty:** The machine might need a thorough cleaning, especially around the infuser housing. 3. **The drip tray or grounds container is full or misplaced:** Make sure they are empty and correctly positioned. If you can provide more details about what you're seeing on the display, I can give you more specific help! --- Once we figure this out, we could also: * Find the user manual for your ECAM 25.462B model. * Look up a video tutorial on how to perform a full descaling cycle. * Check for common maintenance tips for your specific machine.
12/2/2025 7:39:56 PM • Coffee Makers &... • Answered on Dec 02, 2025
Newco CBD-1.5 Dual Commercial Barista Coffee Brewer Logo
1 questions posted
Top Newco Coffee Makers & Espresso Machines Experts
ADMIN Andrew
ADMIN Andrew
john h
Kolbrun...
Are you a Newco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Newco Coffee Makers & Espresso...
  • Newco Coffee Makers & Espresso...
Most Popular Question
need brew coffee
  • Coffee Makers & Espresso Machines
