20 Most Recent Shark Rotator Professional Lift-Away Vacuum, NV502 - lift-away vacuum Questions & Answers
3answers
The brush roll works for a second than red light goes on and it stops. No obstructions to stop the rotation
First make sure that there is no threads wrapped around the roller brush at each end. Next place a couple drops of motor oil in the crack at each end of the roller brush to lubricate the bearings. Do not over oil or you will get oil on your carpet. Now try starting the vacuum on the kitchen floor.. If it still shuts off, then the motor windings are shorted out, meaning the motor is defective and needs replaced. If the vacuum cleaner costs about $ 100.00 , you would be better off buying a brand new vacuum cleaner, rather than replacing the motor.
8/7/2022 9:36:24 AM • Shark Rotator... • Answered on Aug 07, 2022
3answers
My Shark rotator is very hard to push at times, easy at other times. What makes it hard to push and how do I fix it?
Does it have a "brushes" lowering/higher switch? Normally due to brushes being too low in particular on deep pile carpets?? check the actual fixings for the rotating brushes are ok and the brush not simply need "clicking" back into place?
11/23/2021 8:39:08 AM • Shark Rotator... • Answered on Nov 23, 2021
Why is my Shark nv500 vaccum carpet brush is not spinning?
I am having the same issue. The brush won't even move when I turn it with my hand. I just posted this same question.
6/23/2017 11:47:34 AM • Shark Rotator... • Answered on Jun 23, 2017
3answers
I need to replace the filters for my vacuum but I cannot find them for model NV502. Help!
Which filter are you looking for? Is it the foam filter in the bottom of the unit or the HEPA exhaust filter?. Ive found both on Amazon. Amazon com 1 Shark NV500 HEPA Filter Fits Shark Rotator Pro Lift Away...
10/28/2016 10:37:51 PM • Shark Rotator... • Answered on Oct 28, 2016
The brush is not turning on my shark
Check to see that the belt has not broken or off of the roller.
11/6/2015 1:54:21 AM • Shark Rotator... • Answered on Nov 06, 2015
How do I register my new shark vac.
Send In Card That Came With It--Or Go To Their Website And Register (you will need to provide Serial Number)
7/7/2015 9:33:37 PM • Shark Rotator... • Answered on Jul 07, 2015
The vaccum continues to shut down and Shark troubleshoot suggest the thermastat. Instructions followed but problem persists.
the burning odour will be from an over heating motor ( overload switch is cutting in ) have it checked out by an accredited service agent for the machine
6/25/2015 1:57:35 AM • Shark Rotator... • Answered on Jun 25, 2015
Hi there just trying to find out if my Shark is on order they took all my details a we are coming up 3 weeks and still no word
Surely you would be best to ask the company you placed the order with.
5/18/2015 10:36:01 PM • Shark Rotator... • Answered on May 18, 2015
The brush roller has stopped spinning and all the hair has been removed, how do I fix it?
Hey this is Jim with Crucial Vacuum, If there's no noticeable debris on the brush roll try manually rotating it to help unearth any hidden clogs behind it. Take note of the condition of the bristles while you're doing this. If they look worn down, or loose then its time to replace your brush roll. Check your vacuums belt as well. Overtime your belt will stretch and loose resistance. This could lead to the brush roll no longer turning. Be sure your belt is on nice and tight to ensure optimal performance. Your belt should be changed every 3 to 6 months depending on usage. You can purchase a wide variety of replacement belts for your Shark vacuum directly from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 http://www.crucialvacuum.com/shark.html?limit=all I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you. Jim Thompson Crucial Vacuum Customer Care http://www.crucialvacuum.com
5/4/2015 2:25:57 PM • Shark Rotator... • Answered on May 04, 2015
The brush roller has stopped spinning and all the hair has been removed. How do I fix it?
Hey Kathy this is Jim with Crucial Vacuum, Chances are if you've cleaned out all of the debris by your Sharks brushroll and its still not spinning that means there's an issue with your belt. On average you should change your belt every 3 months. After a while the belt will loose tension and stretch and in most cases the brush roll will stop spinning completely. If you're looking for replacement parts to your Shark vacuum you can purchase them directly from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 http://www.crucialvacuum.com/shark.html?limit=all I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you. Jim Thompson Crucial Vacuum Customer Care http://www.crucialvacuum.com
4/30/2015 9:32:33 PM • Shark Rotator... • Answered on Apr 30, 2015
3answers
Model number NV501 seems to be running hot. what should I check for?
i think the coil lamination have got shorted or there may be any shorting of circuit. you should get it repaired without anymore use.
6/20/2014 7:36:20 PM • Shark Rotator... • Answered on Jun 20, 2014
Shark Rotator Professional Lift-Away Vacuum, NV502 - lift-away vacuum Logo
28 questions posted
Top Shark Vacuums Experts
vince
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Shark Vacuums
  • Shark Vacuums
Most Popular Question
need replace filters vacuum but cannot
  • Vacuums
