20 Most Recent Gateway Desktop / Intel Core i3 Processor / 8GB Memory / 1TB Hard Drive (DX484011E) Questions & Answers
With using, the computer without reason/ warning got stuck and I forced turn off the computer; then, tried to turn on again. It was not Boot. The power on, but it is stuck in there, no Boot. Help!
I think yiu also need to check your RAMs. Just use the one RAM and try by replacing and cleaning one by one. Thats only option you can check it.
5/17/2016 11:00:23 AM • Gateway Desktop... • Answered on May 17, 2016
Computer Crashes Error Code: Kernel-Power 41 (63)
The problem may still be your audio. If you go into the bios and switch the audio off and the problem disappears then you will need a separate audio card in a PCI slot.
2/13/2013 2:43:04 PM • Gateway Desktop... • Answered on Feb 13, 2013
Having problems upgrading my GatewayDX4840-11e to 32GB of memory.
Memory Type: DDR3 PC3-10600, DDR3 PC3-12800, DDR3 PC3-8500, DDR3 PC3-14900, DDR3 (non-ECC)Maximum Memory: 32GB Slots: 4Each memory slot can hold DDR3 PC3-10600, DDR3 PC3-12800, DDR3 PC3-8500, DDR3 PC3-14900 with a maximum of 16GB kit (8GBx2) per slot.**Not to exceed manufacturer supported memory.icon_note.gif
Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.icon_note.gif
How much memory your Windows OS will recognize depends on which version of Windows you are running. To utilize more memory, install a 64-bit version of your OS.
Thank You
TomMiller
Eng
8/24/2012 11:36:26 PM • Gateway Desktop... • Answered on Aug 24, 2012
What is the best way to keep these computers
Hello, I am the technician that you be assisting you today. My name is Norman-Wynne Damstra.Welcome to Fixya Jeffery.Yes you are quite correct, your upgraded computer system is giving off a large amount of heat, that graphics upgrade is quite substantial.See these off the shelf PC's from manufactures really don't take the computer gamer's needs into account with regards to cooling. Gaming gear gives off a whole bunch of heat and this heat as you have come to find needs to be expelled quite quickly for a stable and cool gaming computer system.Here are two possible solutions for this problem:Option 1.) Installing cooling into the side panel is the easiest, most effective way of cooling your computer's components. I would reccomend installing at least two 120mm fans. What you do is set the one so that the fans hub would sits directly above the CPU. This fan would therefore provide freash cool air from outside the chassis to your CPU cooler.The second fan would be installed so that the hub sits slightly below the Circuit Board (PCB) of the Graphics card. This fan would therefore provide freash cool air from outside the chassis to your Graphics card. Be sure to check that the fan, once installed over the Graphics card clears the actual graphics card once the side panel is slid closed.You will need to measure and drill 4 holes for each fan, and then cut out the metal in the middle for air to pass through the chassis side panel. One can buy 120mm fan grills to protect anything large from touching the fan blades, it also makes the mod look smart and finished off. They are bought in crome or black finish. Check your computer store.Now that the intake is sorted your will need to work on a suitable spot to install exhaust fans. Some-times there is enough space around the rear 80mm fan to drill and fit a 120mm fan. Again you will need to drill 4 holes and cut away the middle of the chassis for the air to pass through the chassis. You will need to check if this option is available to you. Another exhaust option is the top of the chassis for natural convection currents (hot air rising), usually install either 1 or 2 120mm fans depending on the position of the Power Supply, as some are fitted on the top and others on the bottom.Visit your local computer store for fan mounting; kits, ideas, available fan speeds and airflow rates, purchase fans.Option 2.) Involves the purchase of a suitable gaming computer chassis. These would be better suited to your gaming setup/needs and have lot's of fan install points. You would want to get one, if you so choose that offers 120mm or 140mm fan mounting options. Usually offering in excess of 3 mounting points. Giving your computer components freash air, thereby decreasing tempreature, increasing performance, reliability and longevity.There are lot of diffent sizes and styles available.I would reccomend either Cooler Master 690 series or Corsair.Take care!Norman-Wynne Damstra
11/20/2011 9:17:54 PM • Gateway Desktop... • Answered on Nov 20, 2011
My GATEWAY DX4840-11e did not power up, so I
CMOS Checksum Error, and having to set the Date/Time repeatedly, generally points to a bad CMOS battery.
If it were I, I would replace the battery with a new one. However this is what I would do.
Your computer is still under warranty. Opening the computer case may void the warranty.
Therefore you may not come to the same decision that I would.
On the motherboard is a round flat battery about the size of a U.S. Nickle.
It's a type of watch battery. Generally a CR2032.
Example;
http://en.wikipedia.org/wiki/CR2032_battery
A CMOS battery will generally last from 4 to 7 years. Perhaps the CMOS battery installed in your Gateway is bad. Just a lemon that came from the battery factory.
The battery holder on the motherboard is rounded in shape to fit the battery, and has a metal clip inside. There are different styles of fastening used in the clip design, but generally a small tab of the clip is eased to the outside edge of the battery holder, thereby releasing the battery.
This article will 'shed more light' on the various styles of CMOS battery holders,
http://www.hardwaresecrets.com/article/81
Proper procedure in order to replace the CMOS battery;
1) Unplug the computer from power.
[NOTE* Always unplug the power cord from the surge protector, and not from the computer's Power Supply. (Back of the computer) Unplugging from the Power Supply MAY cause a voltage spike. ]
2) Observe Anti-Static Precautions
Anti-Static Precautions:
Your body carries Static electricity.
Static will fry out (Short Circuit) the delicate hardware components inside a computer.
ALWAYS relieve your body of Static BEFORE working on a computer.
Computer unplugged from power, computer case open, TOUCH the metal frame of the open computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
3) Opening the computer case:
This is Gateway Support, and the Support Documents page for the Gateway DX4840 series of Desktop Computers,
http://support.gateway.com/us/en/s/desktop/2010/gateway/dx/dx4840/DX4840nv.shtml
I would like you to click on - Product Views.
Now click on Rear View.
Observing the rear of the computer look at the right side. Along the edge down towards the bottom is a screw. This screw is removed, then the Side Panel is pulled towards the rear of the computer.
(There is a raised portion, or hump, in the Side Panel for placing your fingers)
If your Gateway DX4840-11e desktop computer has an Asus M2N32-SLI Deluxe motherboard, the CMOS battery is located down towards the bottom of the motherboard, and slightly to the right.
For additional questions, or clarification to what I have stated, please post in a Comment.
Regards,
joecoolvette
5/8/2011 12:15:28 PM • Gateway Desktop... • Answered on May 08, 2011
Gateway dx4840-11e. During video can hear music
do you have the sound set to surrond sound? What it sounds like is that it is trying to play through surrond speakers but you dont have them, which is why you can hear the music and not the actors voices. click with the right mouse button on the speaker in the bottom right of your screen, then click on sounds , now click on the playback tab in the sound window, click on the sound device shown and then click configure, choose stereo and choose two speakers. Continue to the end then try to play the video and see if you can now hear the voices. If you cant then you maybe missing codecs needed to play the audio correctly. Please state if this is a movie you have downloaded or a dvd film on disc etc
4/2/2011 9:35:18 PM • Gateway Desktop... • Answered on Apr 02, 2011
5answers
Best Way to Troubleshoot Payment Gateway Integration Issues on Shopify?
Los problemas con la integraci?n de pasarelas de pago en Shopify suelen deberse a configuraciones incorrectas o credenciales desactualizadas. Una buena pr?ctica es verificar las credenciales de acceso, algo similar a lo que se hace en usuario contrase?a, asegurando que los datos sean correctos y est?n sincronizados con el proveedor del servicio. Tambi?n conviene probar en modo sandbox antes de habilitar los pagos reales para evitar errores.
5/28/2026 2:30:06 PM • Gateway... • Answered on May 28, 2026
How do I change my Telstra NBN gateway password on my iPad please?
To change your Telstra NBN gateway (modem/router) password using your iPad, you need to access the modem's settings via a web browser. Step 1: Connect your iPad to the Telstra Gateway Network Ensure your iPad is connected to the Wi-Fi network of the Telstra Smart Modem you want to change the password for. You must be connected to this network to access its settings; this cannot be done remotely. Step 2: Access the Modem Settings Page
  1. Open your preferred web browser on your iPad (Safari, Chrome, etc.).
  2. In the address bar, type one of the following addresses and press Go or Enter:
    • http://mymodem
    • http://192.168.0.1
    • http://10.0.0.138 (for certain older models)
Step 3: Log in to the Modem Interface
  1. A login page will appear asking for a username and password.
  2. The default login credentials are usually printed on a sticker on the bottom or back of your Telstra modem. The default username is often admin. The default password will be a specific sequence of characters listed on the sticker.
Step 4: Change the Wi-Fi Password
  1. Once logged in, navigate to the Wi-Fi or Wireless settings section. The exact name varies depending on the modem generation.
  2. Look for the field labeled Wi-Fi Security Key, Security Password, or Passphrase.
  3. Enter your new desired password in this field. It's recommended to use a strong, unique password for better security. You may also consider changing the network name (SSID) here if you wish.
  4. Select Apply, Save, or Save Changes to implement the new password.
  5. Your modem may reboot, and all devices (including your iPad) will be disconnected from the network.
Step 5: Reconnect Your iPad with the New Password
  1. Go to the Settings app on your iPad.
  2. Tap on Wi-Fi.
  3. Select your network name (SSID).
  4. Enter the new password you just created to reconnect to the internet.
If you run into issues, you can find more detailed instructions specific to your modem model on the Telstra Support website.
1/13/2026 3:43:24 AM • Gateway... • Answered on Jan 13, 2026
2answers
Surfboard Arris gateway 6700 solid blue LEDs, still no internet
There could be a configuration that is set in the network, a firewall or proxy setting that is misconfigured. You could call your internet provider and ask them to run diagnostics on the router. You could also try connecting over wired Ethernet instead of Wi-Fi. In a worst case senario, you could factory reset the router, then reconnect using its default name and password.
1/13/2026 3:39:36 AM • Gateway... • Answered on Jan 13, 2026
What is the best payment gateway for WooCommerce / WordPress?
I think the best choice can be a little subjective, and depends on what your needs are. Personally, I do a lot of international business especially in Asia, India and some of the other neighbouring countries, but I'm not the best at devising complicated codes. So when I'm shopping for a payment gateway, I'm usually looking for something that works well with international trade or with the currency slash area I plan to be marketing to, and something that's pretty easy to plug into a webpage. In my experience, PayUMoney.com has been a great resource for my international work, and it should allow for easy payment gateway integration in Wordpress or most other websites you would need. Their website should offer a pretty simple tutorial on how to make and place a payment button, and doesn't require buyers to make an account, just an email. Best of luck!
2/3/2025 4:10:35 PM • Gateway... • Answered on Feb 03, 2025
2answers
0x0000007b (0xf78d2524, 0xc0000034, 0x00000000
Try resetting the BIOS to default. or
1. On start up, press the F2 or 'Delete' key to enter the BIOS menu.
2. Expand the "Drives" section
3. Go to "SATA Operation"
4. Change this from "RAID Auto/AHCI" to "RAID Auto/ATA".
7/13/2024 7:59:07 AM • Gateway... • Answered on Jul 13, 2024
How does a payment Gateway work?
A Payment Gateway is a middle-man that securely takes money from your customers and sends it to your bank account. ... Merchant securely transfers order information to the payment gateway. The transaction is then routed to the issuing bank or the 3D secure page to request transaction authentication. https://www.quora.com/How-do-payment-gateways-work-technically
5/15/2024 11:05:04 AM • Gateway... • Answered on May 15, 2024
I have the application SuperSU the free edition on my phone and everytime I try to use it to root my phone forwards me to an address on Chrome the simply says 502 bad gateway
you can use kingroot to root your phone. and some root apps might harm yor os i suggest you not to root your phone
3/1/2024 4:28:21 PM • Gateway... • Answered on Mar 01, 2024
I have a Gateway LP2417 monitor and there's No sound.Hoe do I fix it,so I can hear the video that is playing?
This monitor may not have built-in speakers. It may have supported Gateway's monitor mounted sound bar. That sound bar connected to the 3.5 mm audio out on a computer and a DIN port on the monitor. The simplest solution is to connect your source to appropriate speakers. Depending on your audio setup, you could connect the video source to a receiver with HDMI IN and HDMI Out (ARC), computer speakers or an audio extractor. (If you are using an HDMI cable between the Gateway LP2417 and a computer, you may need to reset the audio output to use basic computer speakers (3.5mm jack).) VGA and DVI connections don't support audio so I assume you are using the HDMI port. I hope this helps. Cindy Wells
1/18/2024 10:32:24 PM • Gateway... • Answered on Jan 18, 2024
I have a gateway Zx4931 and the power button is not working. Do I need to replace the power button or can I reconnect the wires?
Re connecting the wires may work without issues.
12/26/2023 5:46:39 PM • Gateway... • Answered on Dec 26, 2023
Do i need a driver for old gateway gmax2000 speakers connected to an old acer-based home built pc my nephew gave me?
No you don't need a driver. These are very plain powered speakers that come with a mains adapter and a lead with a 3.5mm stereo jack at both ends. Plug one in the speaker and the other into the headphone jack on the front or the speaker socket on the back which will either be a socket on the motherboard, or if your son put a sound card in the computer, it will be in a sound card. If it doesn't play straight away, go into Settings - Audio and make sure the sound card or the On-Board Audio is enabled. This shows the cable https://picclick.com/Vintage-Gateway-2000-ACS41-Altec-Lansing-Multimedia-Computer-314990339798.html#&gid=1&pid=1 More here https://www.google.com/search?q=gateway+gmax2000+speakers ..
11/29/2023 12:20:06 AM • Gateway... • Answered on Nov 29, 2023
WATTS REQUIRED FOR GATEWAY LAPTOP NV55C
110 watts for the power supply.
11/21/2023 1:16:48 AM • Gateway... • Answered on Nov 21, 2023
Wiring diagram for LX6200-01
10/30/2023 11:58:58 PM • Gateway... • Answered on Oct 30, 2023
Gateway Desktop / Intel Core i3 Processor / 8GB Memory / 1TB Hard Drive (DX484011E) Logo
8 questions posted
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Computers & Internet
Most Popular Question
computer crashes error code kernel
  • Computers & Internet
