20 Most Recent
Memorex MMP8567 MP3 Player Questions & Answers
Boot error
Problem Solved: My MMP8567 screen read ''boot error shutting down''.
Everytime I plugged it in to the computer the computer would find it but then it would disappear almost immediately.
I downloaded the Updater program from Memorex but it couldn't find the player.
The directions from Memorex said ''Hold down the play button and plug
in usb cable.'' 'Another set of Memorex directions said, ''Hold down
the power button and plug in usb cable.'' Neither worked for me.
SOLUTION: I finally held down the LOCK/UNLOCK button and plugged in
the usb cable. My computer found the player immediately and a software
driver window popped up asking for a driver. I let windows search the
internet and it found and installed the driver. The driver it was
looking for was: ''player recover device class driver'' After windows
confirmed it recognized my mp3 player I started up the Firmware update
program and was able to update the player.
I tried to be clear and detailed. Good Luck ;-)
It says boot error shutting down and my pc won't recognise it
I have also had the same problem. Go to Google mail and type "MMP8567 boot error" in the search. You will get results where there is links to get the firmware. Especially, from FixYa. Down load the firmware and install it in your PC. Then it will format your player and install the new firmware. Your recorded songs will be lost.
Memorex touch mp3 player won't turn on
Mines doing this too - I reset by inserting a paperclip into the tiny reset hole on bottom right side of unit. Pain to have to do every time but it solves issue.
Pre-Loaded Songs
I realize this post is very old, so I'm commenting for posterity's sake. I don't have this particular model, but I had the same problem with my MMP8568. I couldn't delete pre-loaded tracks from WMP or manually from My Computer. The only thing that worked for me was reformatting my device and deleting everything off of it and starting over.
Basically, I went to My Computer and right-clicked on the icon corresponding to my MP3 player. I selected Format from the options and it deleted everything, from my own songs that I loaded to the pre-loaded content. Then, I resynched my music.
I tried EVERYTHING, and this was the only method that worked for me. :/
Boot error
Hello all:
I just resolved this same boot error problem with my Memorex MMP8567 mp3 player. After talking to technical support, they could not resolve it, so I decided to try it myself. Here is what I did step by step:
1. Downloaded and installed the firmware for the player from memorex web site.
2. In windows xp, click on Start>All Programs>Digital Audio Player>Memorex MMP8567 Firmware Download to start the firmware program.
3. Connect the USB cable for the player to the computer's USB port.
4. Remove battery from the mp3 player and connect it to USB cable. At the same time depress and hold BOTH the 'menu' button on the left of the player and the volume control button on the right of the player for a few seconds until you see "initializing" in your firmware software program. Then click on the "format" option within this same firmware program. (Note: this will erase all your files on the player, but will also get rid of whatever is causing the boot errors!)
5. When the firmware program is ready, click on start and wait until it is finished.
6. Your MMP8567 should now work just fine!
I hope this helps out someone. Good luck!!
Katai
Minnesota, USA
Memorex mmp8567 boot error shutting down
Update the firmware. Download directly from Memorex site, Support section.
in usb cable.'' Another set of Memorex directions said, ''Hold down
After windows
I have a mmp8567 and
After windows
Device is detected, but I can't add music, because it undetects
Mmp8567 mp3 player
Well it sounds like you did something to your computer because if it worked one time it should still work, try restarting both your computer and MP3 player and try Sync again. Hope this helps =)
Memorex mp3 player drivers
You can use Windows Media Player to put songs on it. Thats how we do it. i can give you a step by step how to .. if needed mizz.juliax3@yahoo.com is my email
