20 Most Recent Shark GI500 Versatile 1400 Watt Steam Iron 12" Stainless steel soleplate, Anti Drip & Calc, Auto Off, Self Cleaning, Swivel Cord, Soft Handle SERVICED Questions & Answers
CANT GET THE SHARK IRON TO COME BACK ON
Have you checked the fuse?
3/17/2016 12:35:18 AM • Shark GI500... • Answered on Mar 17, 2016
How can I find the "Polyester" setting?
Just put it on the lowest setting that is near to the off position. Polyester can melt on a high heat setting.
10/12/2015 3:57:01 PM • Shark GI500... • Answered on Oct 12, 2015
My B & D iron is leaking rust..it is a self-cleaning iron..how can I remove rust?
Rust leaking from a B&D iron usually happens when water is left inside the tank for too long, or minerals have built up in the steam chamber. Even with a 'Self-Cleaning' feature, you may need a deeper clean. Follow these steps:" Deep Descaling (Vinegar Rinse): Mix a solution of 50% white vinegar and 50% distilled water. Fill the tank to the Max line. Heat and Steam: Set the iron to the highest heat setting and let it sit for 5 minutes. Once hot, hold the iron over a sink and press the Steam Burst button repeatedly. You will see rusty water and brown flakes coming out. Flush with Clean Water: After the vinegar mix is gone, refill the tank with fresh, clean water and repeat the steaming process to ensure all vinegar and loose rust are flushed out. Clean the Soleplate: If there is rust on the outside of the plate, make a paste of baking soda and a little water. Rub it on the cold soleplate with a soft cloth to scrub away the stains without scratching the surface. Prevent Future Rust: * Always empty the water tank completely after every use. Use a mix of tap and distilled water. Use the Self-Clean button at least once a month as maintenance, not just when problems occur. Expert Tip: If the rust continues after 2-3 flushes, the internal coating of the heating chamber may be damaged. In this case, the iron will continue to leak rust and should be replaced to avoid ruining your clothes.
12/28/2025 1:43:41 PM • Irons • Answered on Dec 28, 2025
I have a steamglide iron No. 18491 and I have recently changed the filter. There is more than 3/4 of water in and the iron is flashing the water symbol and prevent me from using the steam option. Why?
"The flashing water symbol on the Russell Hobbs 18491 after a filter change usually indicates an 'Air Lock' or a sensor reset issue. Since your tank is full, try these steps to clear the error:" Prime the Pump (Air Lock Fix): This is the most common cause. When you replace the filter, air can get trapped in the pump. The Fix: With the iron turned ON and hot, press and hold the steam trigger for at least 30-60 seconds. You might hear a loud pumping noise; this is the pump trying to pull water through the new dry filter. Keep holding it until steam starts to come out. Reset the Sensor: Sometimes the electronic board doesn't realize a new filter has been installed. The Fix: Unplug the iron for 5 to 10 minutes. While it is unplugged, remove the water tank and the new filter, then re-insert them firmly. Plug it back in and turn it to the maximum heat setting. Soak the Filter: If the new filter was installed dry, it can resist water flow initially. The Fix: Remove the filter and soak it in a bowl of water for 5 minutes so it is fully saturated, then reinstall it. Check the Magnet: Some tanks have a small floating magnet inside that tells the sensor the water level. If it's stuck at the bottom, the 'water empty' light will flash. Give the tank a gentle shake to see if the float moves. Expert Tip: Always ensure the filter is pushed down completely until it 'clicks' or seats firmly. If it's even a millimeter loose, the sensor will trigger the flashing light as a safety precaution.
12/28/2025 1:40:27 PM • Irons • Answered on Dec 28, 2025
How to check and repair iron thermostat?
"A faulty thermostat is the main reason why an iron either doesn't heat up at all or overheats and burns clothes. Here is how you can check and repair it:" 1. How to Check (Testing): The Click Test: With the iron unplugged, turn the temperature dial slowly from 'Min' to 'Max'. You should hear a distinct "click" sound. If you don't hear a click, the contact points inside are likely stuck or burnt. Multimeter Test (Continuity): Open the rear cover and locate the thermostat terminals. Use a multimeter on the Continuity (Beep) setting. When the dial is ON, the multimeter should beep (closed circuit). When the dial is OFF, there should be no beep (open circuit). If it doesn't beep even when turned to Max, the thermostat is dead. 2. How to Repair: Clean the Contacts: Over time, carbon deposits (black soot) build up between the two metal contact points. Fix: Take a small piece of fine sandpaper or an emery board. Slide it between the contact points and gently rub to clean the carbon. This often restores the electrical connection. Adjust the Calibration: If the iron doesn't get hot enough, there is usually a small adjustment screw on the thermostat assembly. Turning it slightly (usually clockwise) can increase the contact pressure. Straighten Bent Strips: The bimetallic strip can sometimes get bent. If it's visibly warped, you can carefully straighten it with needle-nose pliers, though replacement is safer. Expert Warning: If the ceramic insulator on the thermostat is cracked or the bimetallic strip has lost its "spring," do not attempt a repair. In such cases, replacing the entire thermostat unit is the only safe option to prevent a fire hazard.
12/28/2025 1:37:02 PM • Irons • Answered on Dec 28, 2025
Why is losing water when i use the steam,dosent matter which setting i use
"Leaking or 'spitting' water while using steam is a common issue. If your iron is losing water regardless of the setting, here are the most likely causes and fixes:" Low Temperature: Steam irons require a high temperature to turn water into steam. If the soleplate isn't hot enough, water will leak out instead of vaporizing. Fix: Ensure the dial is set to the 3-dot (Cotton/Linen) setting. Wait for the indicator light to go off before pressing the steam button. Overfilling the Tank: Filling the water beyond the 'MAX' line creates pressure that forces liquid water out through the steam vents. Fix: Always leave a little air space at the top of the tank. Using Distilled Water Only: Paradoxically, 100% distilled water can cause leaking in some models because it boils differently than tap water. Fix: Try a 50/50 mix of tap water and distilled water. Mineral Buildup (Limescale): If calcium builds up inside the steam chamber, it prevents the internal valve from closing properly. Fix: Run a Self-Clean cycle or flush the iron with a 50/50 water and white vinegar solution to clear the internal passages. Faulty Anti-Drip Valve: Modern irons have an 'Anti-Drip' feature. If this internal spring-loaded valve is worn out or stuck with scale, it won't stop water flow when the temperature drops. Expert Tip: To stop immediate leaking, turn the steam selector to the 'OFF' or 'Dry' position while the iron is heating up. Only turn it to 'Steam' once the iron has reached full temperature.
12/28/2025 1:25:35 PM • Irons • Answered on Dec 28, 2025
How to I put water in my f210 type 1 black and decker iron
"Filling the water tank on a Black & Decker F210 Type 1 is simple, but following the correct sequence prevents leaking. Here is how to do it:"
  1. Unplug the Iron: Always ensure the iron is disconnected from the power source before filling.
  2. Set to 'Dry' Mode: Move the steam selector switch to the 'OFF' or 'DRY' position. This prevents water from leaking through the soleplate while you are filling the tank.
  3. Open the Fill Hole: Locate the small cover at the front of the handle and flip it open.
  4. Fill to Max: Tilt the iron slightly and pour in water (preferably distilled or a 50/50 mix) until it reaches the 'MAX' line indicator. Do not overfill.
  5. Heat Up: Close the cover, plug the iron in, and set the temperature. Wait for the light to indicate it is ready before switching back to the 'Steam' setting.
Expert Tip: To prevent mineral buildup, always empty the remaining water from the tank before storing the iron.
12/28/2025 1:01:23 PM • Irons • Answered on Dec 28, 2025
My iron is not heating up flash green not solid green no heat
"A flashing green light with no heat usually means the iron is stuck in Auto-Off or Power Saving mode. Try these steps:"
  1. Reset the Auto-Off: Firmly shake the iron or tilt it back and forth. This triggers the internal motion sensor. If the light becomes solid green, it will start heating up.
  2. Cycle the Power: Unplug the iron from the wall socket for 60 seconds and plug it back in. This resets the internal control board.
  3. Check Temperature Dial: Ensure the dial is set to a high heat setting. If it's set too low, the light may continue to flash as it struggles to maintain a minimum temperature.
  4. Hardware Fault: If the light continues to flash after these steps, the thermal fuse or the heating element has likely failed, and the circuit board is detecting an open circuit.
Expert Tip: Always plug the iron directly into a wall outlet. Using a low-quality extension cord can prevent the iron from getting enough current to reach the 'Solid Green' state.
12/28/2025 12:53:33 PM • Irons • Answered on Dec 28, 2025
My rowena model #is 9100 has stopped steaming. what to do ?
Use the Self-Clean Button: Fill the tank, set it to the highest heat setting, and hold the iron over a sink. Press and hold the 'Self-Clean' button while shaking the iron to flush out debris. Clean the Anti-Calc Valve: Pull out the steam control needle/valve and soak it in white vinegar for a few hours to dissolve calcium buildup. Check the Steam Settings: Ensure the variable steam lever is not set to 'Dry'. Move it back and forth several times to ensure it isn't stuck. Use Tap Water: Rowenta irons are designed to work with regular tap water. If you use 100% distilled water, it can actually cause the iron to stop steaming or leak. Mix 50% tap water with 50% distilled water for best results.
12/27/2025 6:04:26 PM • Irons • Answered on Dec 27, 2025
2answers
Imesa Flatwork Ironer EDD controller error AL2. What does it mean AL2, in Imesa EDD board please?
AL2 is not a recognised error code.
11/6/2024 5:14:45 PM • Irons • Answered on Nov 06, 2024
2answers
My iron has fused can it be repaired. It is an Aquaspeed Autoclean 5375.
Everything can be repaired if enough money and resourses are thrown at it. Is it worth repairing is the main question. I would take it to a repair shop and ask them for a price to repair it. `You can then decide its futire; repair or scrap.
9/13/2024 9:25:54 AM • Irons • Answered on Sep 13, 2024
Iliso iron will not retract
When cords won't retract, it's usually because they were pulled out too far, ie: past the red line on the cord. Retractable cords have a limit to how far they can be pulled out in order for the spring to be able to "rewind" them back. On products with retractable cords, they have a red line near the base of the cord to warn you to stop.
9/5/2024 11:00:45 PM • Irons • Answered on Sep 05, 2024
My Laura star iron is continuously steaming and won't stop My Laura star iron is continuously steaming and won't stop
The steam valve may be partially blocked with scale so it doesn't close properly. You can try disconnecting the iron from the base unit and flushing it several times with the valve open and then closed. If it is possible to disassemble the valve, you can clean the contamination directly. You may also find that the seal or o-ring is worn out. My mother would use only distilled water in her iron, so she never had that problem. I see from the product manual* that yours is "designed for use with tap water" if the filter is used. There's probably a limit to how much lime in the water it will tolerate, but the manual says nothing about that. If the Laurastar Lift Xtra is less than a year old and you were diligent about replacing the filter when you got the replacement alert light, you may be able to get warranty service. *http://image.email.laurastar.com/lib/fe4715707564057e751572/m/3/75bb559a-f7e0-4d65-aa02-6d2bf912641f.pdf
9/5/2024 9:57:45 PM • Irons • Answered on Sep 05, 2024
ELITECH 2400W CERAMIC SOLEPLATE STEAM GENERATOR IRON where can i get a replacement water filter from i cant find it any were on the net please help
Finding replacement parts for specific products can sometimes be challenging, especially if they are not readily available online. Here are some steps you can take to locate a replacement water filter for your Elitech 2400W Ceramic Soleplate Steam Generator Iron:
  1. Contact the Manufacturer: Start by reaching out to the manufacturer of the steam generator iron. They may have spare parts available for purchase or be able to direct you to authorized retailers or distributors who carry replacement water filters.
  2. Check Online Marketplaces: While you mentioned that you couldn't find the water filter online, it's worth checking popular online marketplaces like Amazon, eBay, or Alibaba. Sellers on these platforms often offer a wide range of replacement parts for various appliances.
  3. Visit Local Retailers: Visit local appliance stores or retailers that specialize in household appliances. They may carry replacement parts for steam generator irons or be able to place a special order for the water filter on your behalf.
  4. Search Specific Parts Retailers: Look for retailers that specialize in selling replacement parts for appliances. These retailers may have a wider selection of parts available and could potentially have the water filter you need.
  5. Consider Universal Filters: If you're unable to find an exact replacement water filter for your specific model, consider looking for universal water filters that are compatible with steam generator irons. While they may not be an exact match, they could still work effectively.
  6. Join Online Forums or Communities: Join online forums or communities dedicated to appliance repair or steam generator irons. Members of these communities may have tips or suggestions on where to find replacement parts or may be willing to sell or trade spare parts.
  7. Check with Local Repair Shops: Reach out to local appliance repair shops or service centers. They may have access to a network of suppliers or be able to source the replacement water filter for you.
2/23/2024 6:22:53 PM • Irons • Answered on Feb 23, 2024
My D2030 iron does not heat up the power light and the screen light come on but does not heat up
1...You need to check the iron settings as they have an adjustable knob that controls temperature as well as governs which kind of materials you want to iron. Different clothing materials need different temperature and other settings. Make sure you set the knob carefully. If you are unable to set the knob properly, you can check the user manual and make sure the temperature or heat amount is set at the right point.
2...Another thing that you need to check in order to inspect why the iron press is not heating up is the water reservoir. In some cases, if the water reservoir is empty then the iron press may not be heating up as much as it should.
For this, switch the iron off and make sure it is cool. Switch it on again and top up the water in the reservoir. Now try ironing again to see whether the heat is proper or not.
3....Another thing that you need to check in order to inspect why the iron press is not heating up is the water reservoir. In some cases, if the water reservoir is empty then the iron press may not be heating up as much as it should.
2/14/2024 6:37:11 AM • Irons • Answered on Feb 14, 2024
Elna Press 2000 Ironing Press. Why won't my press close?
Question edited for clarity. Question moved from Elna Sewing Machines No one has reported this issues, so there are no known fixes. The system is simple, just a hinge with a spring to counterbalance some of the weight. Look for something out of place or binding at the hinge area, perhaps the pivot pin is dislodged. https://www.google.com/search?q=elnapress+iron+won%27t+close+properly ..
2/9/2024 7:02:15 PM • Irons • Answered on Feb 09, 2024
My iron is not warm up
please check the pilot lamp is on and lighting, if not, replace the fuse in the wire cod. also check on the internal thermal fuse it might be damaged. if all fuses are fine please measure the resistance of the heating element and verify that the switch is closing properly
2/5/2024 8:17:17 PM • Irons • Answered on Feb 05, 2024
My Phillips 8500 steam generator works but makes a constant clicking sound.
please check the distance between the live and earth surface of the flat iron. the clicking sound could be originating from a possible short circuit
2/5/2024 8:11:39 PM • Irons • Answered on Feb 05, 2024
Hinari hin172 steam iron won't stop steaming
1/4/2024 2:38:48 PM • Irons • Answered on Jan 04, 2024
Tobi Platinum Model EC1710 Garment Steamer. It does not make steam, It is on but doesn't make steam. Poured vinegar in the water tank.
Question edited for clarity and all the typos / spelling errors. Descale it again, but use CLR Descaler which is made for the job. I presume you can feel heat? When using the descaler shake the unit every 5 minutes because the steam valve outlet will be at the top. of the heater chamber. https://www.google.com/search?q=Tobi+Platinum+Model+EC1710+descale Use the mix details for Irons and coffee machines
CLR Calcium, Lime and Rust Remover
CLR Brands https://clrbrands.com > Products > CLR-Household Get rid of stubborn lime, calcium, and rust stains effortlessly with our powerful all-in-one cleaner. Visit CLR Brands now for sparkling, spotless surfaces. ..
12/28/2023 2:26:33 AM • Irons • Answered on Dec 28, 2023
Shark GI500 Versatile 1400 Watt Steam Iron 12" Stainless steel soleplate, Anti Drip & Calc, Auto Off, Self Cleaning, Swivel Cord, Soft Handle SERVICED Logo
Popular Tags
3 questions posted
Top Shark Irons Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
john h
Are you a Shark Iron Expert? Answer questions, earn points and help others
View Most Popular
Shark Irons
  • Shark Irons
Most Popular Question
find polyester setting
  • Irons
