20 Most Recent
Viking Spray Gun: High Pressure Spray Gun 7. 5 Cfm, Fluid Tip Size: 1. 8mm. Air Inlet: 1/4",70PSI Questions & Answers
Spray gun support
Daily clean-up all parts with proper cleaners/solvents. Re-lubricate where lubricant is washed away by cleaning. Moisture traps and compressor tanks must be drained daily.
I do not like it when I get connected to this
Actually you get many tips from this website :
http://vikingdrill.com/Drill_Troubleshoot_Face.html
Below is Troubleshoot sample availabe in this web :
If you have problem with broken Drill because flutes clogged with chips, drill binds in hole (Common in deep holes) then solution are :
- Use a drill with wider flutes and/ or faster helix angle
- Consider polished flutes
- Withdraw drill at regular intervals to clear chips
- If chips are not broken up, consider heavier feeds - or a chip breaker design.
You can take tour through the list to solve your appliance problem
Or you describe your problem here,
Thank you,
Hello, I am using a Detective Special Cap Gun and
Hello, I'm using a Detective Special Cap Gun, but the trigger isn't working properly. It feels loose and doesn't activate the hammer or magazine. Instead, pulling the trigger moves the magazine up and opens the cap gun. I would greatly appreciate any advice you may be able to provide regarding how to resolve this issue. Thank you!
Cannot find Thermostat valve in our Atlas copco GA15ff , I check filter housing cannot find where it is fixed
Atlas Copco compressors typically utilize a thermostat valve or a thermostat switch to regulate the temperature and ensure optimal performance. However, the specific design and components may vary depending on the model and configuration of the compressor.
If you are unable to locate the thermostat valve in your Atlas Copco GA15ff compressor but have found two thermostat switches, it's possible that the compressor uses a different mechanism for temperature control.
Here are a few steps you can take to troubleshoot the issue with the dewpoint temperature:
- Check the Thermostat Switches: Since you've found two thermostat switches, ensure that they are functioning correctly. These switches may be responsible for monitoring different temperature parameters within the compressor.
- Inspect for Malfunctions: If the thermostat switches appear to be functioning properly, inspect other components of the compressor for malfunctions or damage that could affect temperature regulation. This includes checking for leaks, clogs, or faulty sensors.
- Consult the Manual: Refer to the user manual or technical documentation for your Atlas Copco GA15ff compressor. The manual should provide detailed information about the components, including the thermostat valve or switches, and troubleshooting steps for temperature-related issues.
- Contact Atlas Copco Support: If you're still unable to resolve the issue, consider reaching out to Atlas Copco's customer support or technical service department for assistance. They can provide guidance and support based on the specific model and configuration of your compressor.
- Consider Professional Service: If the issue persists and you're unable to identify or resolve the problem on your own, it may be necessary to enlist the help of a qualified technician or compressor service provider. They can conduct a thorough inspection and diagnosis of the compressor to identify and address any underlying issues.
Not sure how much paint
That depends on what type of paint you are using, surface to be painted, and air pressure for the gun.
Some type of paint needs different air pressure.
This is something you will learn by practicing. Try mixing a little of paint with some thinner
and spray using different distances from the surface to be painted.
If paint is not getting well distributed on the surface then try adding some more thinner.
I have the hds780rs0605 I need to know if I can use latex paint for my walls and how to with out it clogging up
Let me start by saying these types of paint sprayers are not usually recommended for painting large things like room walls because you're going to spend a lot of time refilling the paint cup. The cup only holds 20 ounces of paint and that won't go very far on your walls. If all your paint isn't mixed and properly thinned at the same time your walls could end up with a checker board look. You would usually be way further ahead to rent an airless paint sprayer.If you have to use it; first run your paint through a paint strainer, avaliable at any paint or box store (The Home Deopt, Lowes, etc). Even new paint has impurities that will clog paint guns. It's highly recommended you mix in a paint conditioner like Flotrol but not absolutely necessary. Next, you're going to have to experiment with the consistency of the paint to get a good even flow out of the gun. The thinner you have to make the paint to get a good flow, the lighter and more coats you're going to have to apply. It's also recommended to run a paint soaked roller over the wall right after you spray it to even out the paint and remove any overlap marks.
